TR6 Spline play on TR6 axles
rcn491
Member
What I thought was a U joint problem turned out to be slop in the axle spines. Is there an acceptable amount of movement allowed?
If not, does anyone supply new axle half shafts?
Keoke
Hi rcn491, There was a good used set on E-bay a while back from a very reliable seller.---Fwiw-Keoke -Precott,Az /ubbthreads/images/graemlins/cowboy.gif
RJS General TR Wire Wheel Spline Question Triumph 3
T Axle spline lengths Spridgets 0
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
T TR2/3/3A Propeller Shaft Spline Wear Triumph 3
AH67 hub and spline size Austin Healey 1
D Rear Axle Spline Conversion MG 1
J Steering column spline repair? Spridgets 12
SwamperCa Spline hubs to Lug Nut type MG 5
B 3.9 Diff/half shaft/spline question. MG 2
J Need tranny input shaft spline dimension Austin Healey 7
G New Axle spline MG 4
M Layshaft End Play Austin Healey 7
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
M T-Series MG TD 1st/2nd sliding hub end play MG 1
M T-Series TD/TF Steering Free Play Question MG 6
AUSMHLY 1st Motion Shaft Play Austin Healey 3
B MGB Mgb crankshaft end play shims MG 2
Walter74 Steering Box End Play Austin Healey 2
Jayplum TR2/3/3A Steering Box end play Triumph 6
RickPA Play in steering Austin Healey 12
doc50 Adjusting play on steering box? Other British Cars 5
K TR2/3/3A Checking steering box End Play? Triumph 5
D TR4/4A How much play acceptable for input shaft bushing? Triumph 2
matmire 23d4 distributor clockwise play... normal? Spridgets 4
4tecdog Play in first motion shaft on BJ8 Austin Healey 3
J Clutch fork free play on BJ8 How Much? Austin Healey 13
S TR2/3/3A Distributor drive shaft play Triumph 4
RAC68 Calculating Front Hub End-Play Austin Healey 32
TRMark TR4/4A Play in steering pinion & rack mount mod Triumph 3
I TR6 Steering wheel play Triumph 11
Tinkerman TR2/3/3A 1960 TR 3A excessive 3" to 4" steering wheel play. Triumph 2
D T-Series Let's play "What kind of transmission does this go in?" MG 1
Tinkerman TR2/3/3A 1960 TR3 A Steering wheel play or Lash Triumph 2
A LOTS of wheel play Triumph 12
W 100-4 distributor end play Austin Healey 0
RJS Differential Play Returns Triumph 8
TRclassic3 TR2/3/3A diff free play tr3 Triumph 7
glemon Triumphs at Play Triumph 10
T Anybody Want to Play "Identify the Crud"? Triumph 2
lbc_newbie Let's play.."What's my car worth" Spridgets 13
T TR4/4A TR4a steering shaft play Triumph 21
CinneaghTR Let's Play "Name That Part!"-Sidescreen TR Triumph 10
A TR2/3/3A TR3 Trunnion - vertical link play Triumph 10
T Question on play on steering column Triumph 5
L How much play in your steering? Austin Healey 13
Morris No wife, no kids.... time to play Spridgets 11
6 crank end play Triumph 9
KVH TR4/4A TR4A Allowable Half Axle Play Triumph 0
D Steering play Austin Healey 14
Darwin Adjusting steering play? Triumph 7
