Progress: axles and hubs out
drooartz
My night of inspiration last night seems to have worked. I got my motivation going tonight and spent a few hours out in the garage. Got the old axles and hubs out -- used the reverse-the-brake-drum hint and it worked just fine. Had to grind out the inside of the old drum I was using, and then all worked swimmingly.
I've decided to start with the rear end, and work forwards. First is rear diff swap (to a 3.9) and a change to the later style rear brakes. Then reassemble the hubs with new bearings and seals. Finagle the parking brake, and I'll have the rear end pretty well buttoned up. Can't think further ahead than that, but it's a start.
One question -- should I reuse the hubs that came off the Bugeye, or use the ones that were on the donor Midget? Is there a difference between the two?
jlaird
Use the ones you know are good.
drooartz
drooartz
Define good, Jack. I've got no idea if any of the 4 hubs I have are good... the ones on the car seemed to be working fine. The wheels spun and didn't fall off at least. :smile:
tosoutherncars
Are the bearings a good friction fit? No indication of them having spun inside the hub (i.e. a wear ridge?) If so, I'd say you should be good. My $0.02...
tony barnhill
Great Pumpkin - R.I.P
I toss old hubs & buy new...just not worth the effort to take them somewhere to have them micced for thickness & then turned....I mean, rear drums are less that $25 each! What would it cost to run around having them checked & turned?
He is speaking of the hubs not the drums or rotors(discs).
drooartz
drooartz
Correct, Trevor. I'll be buying new drums for sure, but I've now got 2 sets of rear hubs to choose from. I will be installing new bearings and seals, as a while-I'm-in-there project.
I popped the bearings out of the old Bugeye hubs already. I'll have to look and see if I can see any wear signs. The bearings seemed nice and snug in there, but I really don't have anything to compare to.
tosoutherncars
Drew,
You shouldn't need a 20-ton press... a bench vise and the old race should do it. But once they're in, the race shouldn't easily spin in the hub. That's my understanding... Maybe Dug, Peter C or another of our more mechanically-minded alumni will chime in with a more technical response.
The worst part of that job (at least for me) is getting the old seals out. I just don't seem to have the technique/tool to do that without cursing.
drooartz
drooartz
That's actually comforting, Trevor. I tried (briefly) to get the old seal out, then gave up for now. I'll deal with that when I get around to the rebuild portion of this project.
Nope the seal that keeps the oil from flowing out past the bearing.
Kevin, I'm not familiar with that technique. How does that work?
jlaird
The good ones for sure are the ones that came out of the Tunebug.
Bayless More Prefect Progress Other British Cars 2
CARSINC Progress On My 1965 Sprite (update) Spridgets 3
mctriumph 61 Morgan making progress Other British Cars 3
SNClocks Progress Update Spridgets 5
SNClocks Progress Shots! Spridgets 15
prb51 AH Search in Progress Austin Healey 35
C My 2500M progress/questions thread TVR 5
D GT6 9 months later. GT6+ progress Triumph 3
J Restoration Progress - Boot Installed Austin Healey 1
F GT6 Looking to sell - in progress restoration Triumph 19
Cutrog1 How do I respond to all responses and add progress report on original article? FORUM Navigation Questions 3
Bayless More Sprite progress finally Spridgets 23
Bayless Sprite progress faster than expected. Spridgets 3
doc50 1958 Metropolitan Progress Other British Cars 4
Bayless Even more progress - the Prefect Other British Cars 5
Bayless Progress finally begins Spridgets 5
D Progress.... Spridgets 4
Rut TR4/4A Shop progress Triumph 21
Rut Shop progress Spridgets 25
Rut MGB Shop progress MG 4
69MGC MGC Wheel well restoration progress MG 4
69MGC MGC My MGC Restoration Progress MG 4
simon1966 100 Restoration Progress Austin Healey 13
Jim_Gruber Bugsy IV Progress today Spridgets 34
drooartz Making [tiny] progress Spridgets 14
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
Marvin Gruber TR5/TR250 TR250 progress Triumph 15
Jim_Gruber Actually made some progress on Bugsy II Today Spridgets 4
drooartz MGB-GT Other small progress MG 3
D Bugeye Wiring Progress. Spridgets 3
Brinkerhoff T-Series TC restoration progress MG 16
RickB Knox Custom Chrome - my grille progress Spridgets 58
sim In progress 58 paint job by Premire body and paint in Visalia Ca Restoration & Tools 0
jaegzie Long time since I've been here but progress has started. Bigeye rebuild Spridgets 9
Marvin Gruber TR2/3/3A 1956 TR3 in progress Triumph 28
oxford Progress Video Austin Healey 6
2 MGA mga mk II in progress MG 2
7 Post-War Other Back to making progress Triumph 5
N Spitfire 75 Spitfire progress Triumph 6
oxford BN4 progress Austin Healey 8
drooartz MGB Finally some progress -- floors painted MG 4
drooartz MGB Making some progress with the doors MG 5
Darwin Spitfire Joy in Mudville [Spit6 progress] Triumph 1
J TR2/3/3A Need to sell my '56 TR3 restoration in progress Triumph 21
Lin Progress Up-date from Rich Berman and Andrea Austin Healey 10
Pythias 1275 transplant progress. Spridgets 50
64rocksprite Re-assembly progress and a wiper rack question Spridgets 8
M TR2/3/3A TR3 progress pictures Triumph 26
mcguijo Some progress at last Triumph 2
Mychael Progress Latest on the Frogeye. Spridgets 1
