    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
cracked exhaust manifold
Ulf
I am still in the works of trying to get my '77 Midget (1500 engine) through CA smog and when trying to find all kinds of leaks etc I find out the exhaust manifold is cracked almost all around.
What should I do?
Is it weldable or fixable or do I have to try and find a replacement?
jlaird
It is weldable but best bet would be to find a good one. Ask for one here or ask Tony.
aeronca65t
This is very common on 1500 cars. Both of mine were cracked. I think the super-hot catalyst below the manifold is the cause.
I am not sure if you will have any luck welding. You can weld cast iron, but in this circumstance, it may soon crack again. Brazing might work better, but there's no guarantee. Many of us have fitted headers but I realize that may not be an option for you.
U
Ulf
Nahh I have no option that would change the original look or function of the engine.
I gathered that welding or brazing could be an option, but as you say Nial, it seems like a stop gap measure, so off I am to look for a non cracked exhaust manifold. That might not be that easy since it has to be one for the 77-80 (with the catalytic can) and as you said it seems the hot can helps crack them at a rapid pace. I know that moss and VB sell new ones but they are like $450 and that does feel a wee steep.
/quick rant on...
It makes no sense to me that it not only has to get through smog (logical) but has to look and work in a fashion that was flawed over thirty years ago, and can in no way be equal or better than newer solutions.
quick rant off/
Morris
I do not live in California, but I cannot agree more with your rant. If CARB would amend their rules to allow improvements to cars as long as exhaust tests meet or exceed standards set for the specific year the car was made, the net effect would be an overall reduction in air pollution. CARB has done some great things for the air quality of the whole country, but they're attitude towards old cars is backwards and stupid IMHO.
jlaird
Small question will anyone at the smog place know what it is to look like? I bet not. Shoot, I bet they don't even know what kind of car it is.
R
RonMacPherson
CARB used to have in place a "waiver" system. Where the cost of repair, or unobtainium parts would get you a waiver. Might wanna check on the CARB website, see if they still have it available.
A concern though is exhaust leak, you do wanna get it replaced to avoid any possibility of exhaust inhalation for safety purposes.
Have you checked with any of the header folks, or someone like Pierce Manifolds, to see what they have that might help you out?
U
Ulf
Jack, they found the crack, and they know enough to either look up in a book what it should look like, or actually have seen one before.
I tried to get a wavier due to fact that dealers like VB and moss (or any other who lists on the internet) dont sell working EGR valves etc. I got a number to a "hot line" where they dug up people who custom make the parts. So an EGR valve for a Midget is a low $175 etc etc....
Every one I know tells me to ditch this '77 Midget and get an older one ('75 or older who are smog exempt), that is until they realize the Midget I have is my Mentors old car he put in his will to me, so it is to be smoged... /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
jlaird
I'm bad.
Fix crack, take it somewhere else for check.
U
Ulf
Thought about cosmetically fixing the manifold and going to a new place. Would give me a two year window to fix it properly.
No exhaust manifold on his list, but I sent an email... Thanks for the link though... /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
tosoutherncars
Hi Ulf,
I've got a Cali 1500, and I've just installed headers. No problem here in Canada, we're sensible that way! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
I'll double-check to make sure it's not cracked... you're welcome to it, if you'd like.
Best,
Duncan
George Zeck
Just received the 1275 version today from ebay -- will post over the weekend.
George
Morris
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]No exhaust manifold on his list, but I sent an email... Thanks for the link though...[/QUOTE]
That guy does not answer email. You will have to give him a call. And if you scroll down, you will see that he does list manifolds: $75-$150. Guess which one is $150 /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
I hope Duncan can hook you up.
JPSmit
I've got an extra - even has the can if Duncan's doesn't work out - price of shipping - I'll check & see if it's OK
U
Ulf
Thanks JP. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Morris, I did miss the line on his site. If the "canada connection" does not work out I think I will give that place a call.
scoutll Exhaust manifold has cracked-Anyone have a spare? Spridgets 2
N TR2/3/3A TR-3A cracked exhaust manifold Triumph 8
P Cracked windshield Other Cars 0
M TR2/3/3A Cracked Welds on Steering Idler Arm Triumph 5
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
P TR2/3/3A Windshield Cracked Triumph 12
Kleykamp TR2/3/3A Cracked Block??? Triumph 6
D MGB MGB Cracked Cylinder Heads Question MG 4
BoyRacer 6 cyl aluminum head - cracked valveseat Austin Healey 1
TimK 2 cracked windshields Austin Healey 13
aeronca65t Cracked Rostyle Spridgets 6
MCNX_BFF Cracked and leaky Triumph 20
M cracked head ??? Triumph 6
Carlos TR4/4A TR4A cracked cylinder head Triumph 8
Stewart cracked head? MG 7
tweety It wasn't a head gasket or anything cracked..... Spridgets 1
tweety I'm assuming head gasket, cracked block or head??? Spridgets 4
eschneider MGB MGB sunvisor rivets [and now cracked glass] MG 4
Baz Cracked coil spring! Spridgets 25
SilentUnicorn 1500 Cracked head? Spridgets 3
B Piston is cracked MG 7
G TR2/3/3A TR3A cracked frame Triumph 3
J cracked wishbone! Spridgets 17
J New Soft-top, or reupholster cracked window? Triumph 6
G Quarter Light Frames Cracked! MG 0
M TR2/3/3A Cracked TR3 block... Triumph 0
M TR6 Help- TR6 rear shock mount cracked Triumph 3
aeronca65t Cracked WIndshield Restoration & Tools 15
M TR2/3/3A Blown Exhaust Manifold Gaskets Triumph 10
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
