I'll add my experience with Peter. He rebuilt the shocks on both our MGB and MGTD. One of the rear shocks on the TD started leaking and I sent it back to Peter. I got a call from him in about a week saying that they could not find where the shock was leaking, even though they could see that it was leaking and it was going to take a bit to find and fix it. Since the shock wouldn't cooperate with them finding the leak, Peter called and again told me that it was going to take more time to find the problem and I told him to take however much time was needed. After getting the shock, Peter told me that in order to find the leak, he bolted the shock to a wall in a well traveled area of his business, with instructions that every time anyone went past the shock, they were to cycle the lever up and down several times. Doing that, he not only found the leak and not only fixed it, but designed a modification to the shock to correct a deficiency from the factory (from back in the late 40s, early 50s) that was causing the leaks.
Bottom line, Peter goes above and beyond to make sure thing work for the customer - he gets my vote every time!
Cheers,
