MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks?
CZ_Dave
I'm looking into the Shock Conversion kits
or rebuilding a couple of pairs as I have lots of shocks
laying around the shop.
Which do you think would be more efficient?
Is there a youtube video on rebuilding MG Shocks?
Joe Reed
I've never used a tube shock conversion, but it seems that many - maybe even most - think the original shocks are better for a couple of reasons. The shocks typically used in the conversion kits aren't actually designed for the MGB, but are just shocks intended for other applications that happen to be the correct size...and those other applications are heavier than the MGB. Most of them also leave the front shocks in place (without fluid) to continue to serve as an upper control arm.
World Wide in Madison WI is the most often recommended supplier of high quality rebuilt shocks. I don't know if rebuilding them yourself would require special tools, but you may have trouble sourcing any worn internal components.
Flash_Harry
I got all four lever-arm rebuilt shocks from World Wide Auto Parts in 2008, replacing rear tube shocks put on by the previous owner. One shock developed a leak in a short time, and Peter replaced it right away with no problem. The car feels good all the time, drives pretty much like a B-GT should. Just a satisfied customer...
https://www.nosimport.com/Lever-shocks-remanufactured/mg-b-lever-shocks
Joe Reed
I read somewhere that the tube shocks with at least one kit were designed for a Chevy S10 pickup. I don't know if it's true, but if so, I don't think shocks designed for a 4000 pound truck would be ideal for a sports car of almost half that weight!
princetn1
If your car is like most and not 100% original, I would simply go with new shocks and NOT opt for the conversion. Replace what you have since you know it is designed for our MG's. And, if I may be so bold, purchase parts like the from Basil Adams who know everything there is to know about what you need and prices are generally very good.
Sarastro
You might take a look around YouTube. There is a video by John Twist showing some of the problems that can occur with tube-shock conversions. The bottom line, as we yuppies say, is that the success of the conversion depends strongly on the design quality of the conversion kit, and you don't really know how good that quality is. Furthermore, I don't see much advantage to a tube-sock conversion--the lever shocks, in good condition, work fine.
I hate to divert people to other forums, but there was a recent thread in the MG Experience forum regarding rebuilding of Girling TD shocks; I'm sure that other makes and sizes are similar. Start with https://www.mgexp.com/phorum/read.php?46,3173224,3173224#msg-3173224 but there is more if you look for it.
Or just send them to Peter at World Wide Auto Parts--very good work and quite reasonable.
CZ_Dave
CZ_Dave
Thank you everyone, for your input, I appreciate all the positive comments.
Dave
Platinum
:iagree:
Rut
X2...I've got Peter Cs rebuilt shocks on my MGB and Bugeye and will be putting them on my TR4as when the time come. Excellent quality and a lifetime warranty!
Rut
Sarastro
For what it's worth, I had the shocks on my TD done at WWAP, and I was very pleased with the results. I'm not just repeating conventional wisdom.
Sarastro
Gokart
As per JT's vid I would never go for that system where the shock is allong side the coil with bars holding it out there.
If you were to go to tube shocks you need to go for quality and something that is proven.
I got a kit locally from a guy who has worked with and on MG's his whole life and he has the system he sells on his own well used and abused B.
The system is a tubular shock mounted inside the coil. The lever arm shock is completely removed and replaced with a mount bracket for A. the top of the shock to bolt to and B to have a solid aluminium block with offset bore for the arm off a lever shock to mount to.
The aluminium block is offset to allow for camber adjustment. The block is set so you can start with -1 degree camber and by flipping the block over you can get another 1 1/2 degrees of - camber, or anything between and more by adding shims.
I also replaced the rear levers with bilsteins as well.
The tubular shocks used are non adjustable Bilsteins. The type used are selected specifically for the MGB and Bilstein are world reknown for their quality products.
I found it very good as not only did I get my suspension working (very well) with no oil leaks but I got some adjustability in the camber.
I also replaced the anti roll bar with a 7/8 one. The combined front/rear kits and the stronger roll bar has given me a great handling car.
These kits as far as I can tell are based around the same ideas Ron Hopkinson had in the 80s - 90s and he sold his kits with Bilsteins as well.
One has to compare the costs of the kits against getting the levers reconditioned. I wasn't prepared to spend money on a recon when I could get new that worked better (more camber adjustment) with the car.
Of course I replaced all the rubber components in the suspension as well and checked and replaced any bushes and bolts that needed replacing.
Cheers Rob
PAUL161
Peter rebuilt the Armstrong shocks on our 72 B and the shocks on the TF, they are perfect. I wouldn't even consider converting to a tube shock. :encouragement: PJ
David_DuBois
I'll add my experience with Peter. He rebuilt the shocks on both our MGB and MGTD. One of the rear shocks on the TD started leaking and I sent it back to Peter. I got a call from him in about a week saying that they could not find where the shock was leaking, even though they could see that it was leaking and it was going to take a bit to find and fix it. Since the shock wouldn't cooperate with them finding the leak, Peter called and again told me that it was going to take more time to find the problem and I told him to take however much time was needed. After getting the shock, Peter told me that in order to find the leak, he bolted the shock to a wall in a well traveled area of his business, with instructions that every time anyone went past the shock, they were to cycle the lever up and down several times. Doing that, he not only found the leak and not only fixed it, but designed a modification to the shock to correct a deficiency from the factory (from back in the late 40s, early 50s) that was causing the leaks.
Bottom line, Peter goes above and beyond to make sure thing work for the customer - he gets my vote every time!
Cheers,
JPSmit
Cheers,
Brilliant! I I too have a rebuilt shock from Peter. That said, I am really trying to imagine where he mounted the shock?
toilet handle? :grin:
T Double row timing chains - worth doing on a 1275? Spridgets 17
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
AngliaGT MGB '74 MGB GT - Is it Worth it? MG 3
nichola TR6 Resurrecting a water pump, worth it? Triumph 7
roscoe Not Healey but the puns are worth it Austin Healey 7
JPSmit Worth Something Somewhere else Spridgets 7
roscoe Worth reading Austin Healey 3
Got_All_4 TR6 Is this head toast or worth fixing Triumph 3
Got_All_4 TR6 What is a 1969 TR6 seat worth? Triumph 5
T TR4/4A TR4A/TR250 what are they worth Triumph 8
GTP1960 Here's one worth a second look. Other Cars 1
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
glemon MGB What is a nice MGB worth MG 5
B Whats my car worth? Austin Healey 5
T TR4/4A Are the ARP head studs worth it? [ducks for cover] Triumph 19
T what is a steering wheel worth for a BE? Spridgets 1
Got_All_4 TR4/4A What is the car worth [detroit locker] Triumph 8
T GT6 Opinions on what a rust free GT6 is worth Triumph 22
drambuie Healey100S film worth seeing again! Austin Healey 0
WillR MGB transmission seals worth replacing? MG 8
AN5Sprite Post-War Other What's a '64 Herald Worth? Triumph 6
S TR6 Worth Saving??? What do you think we should do? Triumph 30
S Worth A Thousand Words Spridgets 11
Jim_Gruber Not LBC but British Car Related - Bathhurst 1000 finish- worth a look Spridgets 3
B TR2/3/3A Is a 63 TCF probably needing total restoration worth getting into? Triumph 16
J TR6 What are Original TR6 wheels with Michelin Red Lines worth? Triumph 11
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
C 2016 Jaguar F-Type with manual shift...worth it? Jaguar 7
HealeyRick Old BJ7 Block. Worth Anything? Austin Healey 8
I TR6 What is a car worth? Triumph 6
L Another what is it worth Austin Healey 15
HEALEYJAG Whats it worth>>>3000 MkI Austin Healey 11
Editor_Reid "Paddy Power" video - well worth watching! Austin Healey 12
K TR2/3/3A What's a TR3 steel hardtop worth? Triumph 7
PATR8 Spitfire What is a 1968 Spitfire worth? Triumph 11
69sprite Console & armrest - is it worth it? Spridgets 13
C TR5/TR250 TR250 Worth restoring Triumph 18
HealeyRick Which Is Worth More? Austin Healey 24
60TR3A TR4/4A What's a Supposedly Concours Condition TR4A Worth? Triumph 24
N Abandoned project; what's it worth? Austin Healey 47
me61ic Compression results - Worth Rebuiding? Austin Healey 13
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
Medent MGA What's this MGA worth? MG 11
Pythias 1098 worth saving? Spridgets 29
Atrus What's it worth? Spridgets 4
C BN6 Complete Running Gear - What's it worth? Austin Healey 18
britlover What is a completely original 1954 100-4 worth? Austin Healey 46
britlover TR6 What is an unmolested, rust-free '75 TR6 worth ? Triumph 4
C MKX Worth IT? Jaguar 15
M Is it worth $1200 Spridgets 15
