TR2/3/3A What's a TR3 steel hardtop worth?
karls59tr
Bronze
I know it depends on condition and whatever the market will bear but what is the ballpark price that original TR3 Hardtops go for?
PeterK
A good one with all the hardware, rear window will top $1K. Install kits are $250 when available.
Geo Hahn
As I recall, the hardtop bits on mine included brackets under the rear capping, chrome finishers on top of the capping and chrome brackets that mounted to the top edge of the windscreen frame. I removed mine and gave them away as I knew I would never use them.
Possibly all cars got the fittings that are concealed under the rear capping -- I am unsure about that.
Gordon_Dedrick
I believe the Roadster Factory still has mounting kits available.....they are not cheap however. Every once in a while you'll find some on E-Bay. As far as value goes Hagerty rates them as + $1000. Real easy to get that much invested if they need body, rust work, paint and mounting parts! I have a Parish Fiberglas aftermarket unit and the mounting parts I needed for it were almost $200.
Gordon
PeterK
Original window was Persplex (~=plexiglass.) I think that the kits for attaching to you car cost around $250-300 MossEU when you can find one.
G TR2/3/3A tr3 steel hardtop Triumph 12
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
D TR2/3/3A TR3 Steel Wheels Triumph 7
T TR2/3/3A TR3 steel wheels Triumph 6
Scotsman TR2/3/3A Should inner tubes be used with TR3 OEM steel wheels Triumph 3
af3683 TR2/3/3A TR3 Stainless Steel Exhaust Triumph 5
T TR2/3/3A What gauge steel use for TR3 frame? Triumph 3
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
K TR2/3/3A What is a set of good used TR3 steel wheels worth? Triumph 18
T TR2/3/3A TR3 steel wheels - always silver? Triumph 2
S TR2/3/3A rad steel pipe tr3 Triumph 2
fad64b TR2/3/3A TR3 steel wheel color Triumph 6
T TR2/3/3A Tr3 steel wheels Triumph 12
