Yes, I have too cars. Sidescreen help
tdskip
Been picking at the pile of parts and am hoping you guys can help me identify which side screen is which here.
The choices are Bugeye, MGA and TR3a. I think anyway - ha.
Thanks!
Mickey Richaud
Not sure about the first set. Second set (with flaps) are TR3 (aftermarket, due to the rubber around the metal frames.
drooartz
First set looks Bugeye to me, Tom.
TR3driver
Great Pumpkin - R.I.P
Do you have the mounting legs for them?
T
tdskip
Hi Randall - I do, they are still attached under the curtain (rubber/plastic skirt). The skirts are torn from the heat.
TR3driver
Might be worth trying to recover them then, if they fit your car and you like the style. The rubber flap would engage a flap on the top as I recall, making them somewhat more weather-tight than the stock ones.
But I am guessing they are wedge style, from the LTD fastener on the flap, which means they would only fit TR3 through very early 3A.
T
tdskip
But I am guessing they are wedge style, from the LTD fastener on the flap, which means they would only fit TR2 through very early 3A.
Is there a VIN cut off, or date range for what should fit by chance?
TR3driver
SPC shows TS28826 should be the first car with the Dzus style sidecurtains.
TR4nut
Isn't lift the dot for later cars? Tenax would be earlier?
TR3driver
Tenax would only be much earlier cars, up to TS5255 according to the SPC. TS13571L has LTD studs on the doors.
The Dzus style sidecurtains didn't have snaps at all, they were stiff and held only by the brackets. But the bottom half of the earlier sidecurtains was flexible and secured by snaps.
Hmm, well, that applies to the factory sidecurtains. There might have been some aftermarket ones that fit the Dzus sockets but had snaps.
JohnnyMead
I've got the after-market style with Dzus fittings. They have lift-the-dot snaps around the edge of the flaps rather than the single inside fastener.
John
60 TR3A
On most of the aftermarket wedge type side curtains I've seen, you can remove the piece of aluminum that is welded on the legs to make the wedge, then drill hole for the dzus to fit so you can use them on later TR3's. Personally if you are going to rebuild some side curtains use the original style. I have several sets if you want to rebuild some.
apbos
I have been thinking that those aftermarket sidescreens would be great to mount on a removable mount on the Racetorations competition sidescreens in bad weather. Racetorations.com
Paul
PSI have a set of the competition sidescreens
Popeye General TR Battery Tray - yes or no? Triumph 11
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
T This is going to be a huge amount of work, yes? British Motor Corp 4
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
JPSmit Yes Please! Spridgets 0
Rob Glasgow Healey 1000/4 yes 1000/4!! Austin Healey 5
Rob Glasgow Healey 1000/4 yes 1000/4!! Austin Healey 0
Jim_Gruber Bugsy IV's First Drive - Yes He is Legal and now on the road Spridgets 12
Z MGB My 5.8 OHC Rover V8 build yes this is a P76 block from do under! MG 10
M TR4/4A Underhood/Bonnet insulation...Yes...No ? Triumph 3
JPSmit Yes, I know it is a Kit Car Other Cars 1
drooartz MGB Yes, I drive with the top up MG 5
luke44 TR2/3/3A TR3 Center Mirror - Support Bracket. Yes or No? Triumph 7
AH67 How to open hood? Yes i'm serious. Austin Healey 5
Tr3aguy Stripped parts...yes Triumph 8
M this carb set up, yes or no Spridgets 11
QuickSilver Yes, I'm A Glutton For Punishment Rover / Land Rover 6
RickB Seats Sprite Mk II / Midget Mk I [yes, again] Spridgets 23
T Ratcheting wrenches! YES! Restoration & Tools 23
T Yes, Virginia, there is a Santa Claus Triumph 7
B Have mercy..am I insane?? Yes! Spridgets 22
C Supercharged Jag V-12 in a Healey 100? - YES! Austin Healey 1
timbn2 Are these 100-4 seats... yes or no? Austin Healey 8
kodanja TR4/4A New TR4.....? yes /no... Triumph 5
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
Bret Just say YES to Roadsters! Other Cars 9
B TR6 Yes.....another TR6 tire size question Triumph 7
TRclassic3 Yes, another high idle string Triumph 21
zimmy Rustoleum......yes, once again...... Spridgets 42
Atrus Yes, another electronic ignition question Spridgets 2
B New Midget, Yes another one Spridgets 51
kyreb1862 Next Question.........Oil Coolers [Yes or No] MG 10
Brosky Pacesetter Headers Yes or No? Triumph 13
jaybird Yes! Engine's done! MG 42
G YES!!!!!! I WAS RIGHT!!!!! Triumph 2
t8nwa NEW, yes new, Triumph car rumor Triumph 31
Steve_S Dodge Challenger. Yes, Dodge Challenger. Other Cars 33
bluemiata90 TR2/3/3A TR3A rack and pinion conversion-yes or no Triumph 8
Jim_Webby TR4/4A Free [yes, free] TR4 available in Michigan Triumph 31
J connie chung's car [yes, THE connie chung!] Austin Healey 9
P TR4/4A Birch Grey TR4A .... yes or no ? Triumph 19
Sherlock Yes... we have some nice cars in the frozen north Other British Cars 9
P lighten flywheel - yes or no ????? Triumph 4
J TR4/4A Exhaust a tad too loud... Triumph 6
jfarris Message too long error FORUM Navigation Questions 8
mctriumph TR2/3/3A The concept of too many Triumph 8
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
R For Sale Conundrum - Too Many Bugeyes Spridgets Classified 1
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
