TR6 window regulator
sundown
I removed the window regulator on the passenger side, had to strengthen up the piece the handle attaches to reinstalled it put the door panel back on, put the handles back (pain installing the handle pins) everything looks great went back to my workbench and saw the big spring that I forgot to put on the front of the winder that clips on the door my question is what part does that spring play for the working of the window really do no twant to do that all over again Thanks
TR3driver
Great Pumpkin - R.I.P
If it's the "clock spring" one I think you are talking about; then it serves as counter-weight for the weight of the glass. Without it, the window will be very hard to roll up, and likely increase wear in the winder mechanism.
trrdster2000
Sundown, if your panel fits good and no rattle from that area, you will not be the first to discard that spring. It's even more of a pain to install the pin with it on.
Wayne
pdplot
I once forgot that spring. The door handle drooped and was loose. Re-installing the spring was a PITA but cured the problem.
SpeedyG TR4/4A Door window regulator spring Triumph 5
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
B TR4/4A Window Regulator Leather Washers Triumph 6
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
waltesefalcon Window regulator Other Cars 1
M TR4/4A Another question on window regulator. Triumph 3
M TR4/4A Window regulator assistance please. Triumph 1
sundown TR6 1973 TR window regulator Triumph 2
2wrench TR6 Help installing door handles/window regulator handles. Triumph 9
D Don't ignore stiff window regulator Austin Healey 8
Tim Tucker TR4/4A TR4 STOP BRACKET for WINDOW REGULATOR Triumph 5
H TR4/4A Window Regulator 4a Triumph 0
AUSMHLY Window Regulator BJ7 vs BJ8 Austin Healey 26
E TR4/4A TR4 Window regulator Triumph 2
D Spitfire '65 Spit window regulator installation tips needed Triumph 0
D Spitfire WTB window regulator, passenger side, '65 Spitfire Triumph 3
AUSMHLY Window Regulator repair Austin Healey 3
BubbleTop61 Window regulator interchagebility MG 6
H Lubrication of Window Regulator Hardware Other British Cars 3
3 TR6 TR6 window regulator channel. Triumph 8
S Window Regulator Compatibility MG 2
O Jaguar rear window trim repair Jaguar 1
Bayless How to repair broken vent window studs? Spridgets 1
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
algot1901 Window Channel Ford Prefect Other British Cars 5
DrEntropy Benz electric window battle Other Cars 13
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
Robert Somma power window installation TVR 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
HealeyRick BJ7 Side Window Alignment Austin Healey 31
nichola TR6 Door handle and window crank installation Triumph 0
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
T Early BJ7 Vent Window Seal Austin Healey 2
P TR6 Tight window crank Triumph 9
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
B TR4/4A Window Channels Triumph 6
JFS Wedge Door wing window finisher Triumph 2
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
A PLATE, handle locking on Vent Window Austin Healey 0
B Side window question for early Longbridge BN4 Austin Healey 4
T TR6 Frosted rear plastic window Triumph 6
G BJ7 Window channel position Austin Healey 1
P Rivets on windshield and vent window frame. Austin Healey 1
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
B BJ8 vent window collar fused on Austin Healey 7
M Zip-Out Rear Window on a BN-7 Top? Austin Healey 11
Zitch TR4/4A Window Guide Writeup Triumph 2
M window rattles Austin Healey 5
Scotsman TR4/4A Need FELT for window channel Triumph 8
