I need to take my vent window apart to install new seals. The collar seems to be fused on the pivot. I think they are intended to be separate parts but time has fused them together. I've used all typical techniques to pull it off (penetrating oil, heat, big pliers...) I don't think the pivot and collar are made anymore unless someone gives me a lead.
Any thoughts? Wondering if I can find a collar in the hardware store with a set screw or similar because I think I need to cut the collar off.
