TR6 Tight window crank
pdplot
Bronze
Driver door window regulator was replaced in 2012. It has never been easy to operate. I oiled it when I installed it but it did no good. The passenger side works smoothly with little effort but the driver side is so bad I can't get it all the way up from the driver seat. Takes two hands. I put some silicone lubrication in the window tracks but that didn't help. I know the door panel will have to come off again but what after that? Anyone cure this problem?
mctriumph
Often the issue is the angle of the regulator as related to the anchor bolt. The hole gets wallowed out
and must be fixed.
. Make double sure the felts in the vertical guides are fine. They get torn and can bunch up
causing drag. The balance spring can be weak also, NEVER put too much faith in new parts.
MD(mad dog)
charleyf
Bronze
I had both windows on the TR4 doing as yours is doing. I took off the panel and just tried to adjust the mechanism some. I do not know exactly what I did but it has been working very well since then. I know that I did loosen some parts and then adjust and retighten them. There are not a lot of things that you can do but keep working on it until it moves as you want it to.
Madflyer
Felt will make it hard and the spring should have some lube but the biggest problem tracks out of line. So loosen track at bottom of door and run glass up and down find a happy place it may need a shim if say door is bent. Do you have good door gaps to body. Madflyer
charleyf
Bronze
The first couple of turns are easy - then it binds and becomes hard to crank.
Yes that is exactly what mine was doing. Wish I could be more specific. I cleaned, lubed and tried to adjust. Got it working great with NO NEW parts.
P
pdplot
Bronze
Those %^%$# handles! What a stupid system. I did this job once and swore never again. The springs are very tight and you need 3 hands to push on the panel and insert the icepick I use to get the pin out. There must be a forked tool to make the job easier by wedging the panel and the plastic spacer. Of course the pins fall out and disappear so I just cut a nail to the right size and stick it back in with a pair of needle nose pliers. People have drilled out the handle and crank and tapped it for a plated machine screw like a normal car. Wonder what would happen if I drilled out with the handle still attached? Would the handle then slide off or would there still be part of the pin preventing the handle from coming off? Anyone ever try it? Just wondering.
mctriumph
Calm down, cut down the spring where it is at least humanly possible to re-assemble the little bugger. Sometimes we
will heat them to get less height/tension . the issue is the new springs are way too much for the job.
MD(mad dog)
P
pdplot
Bronze
I had the perfect tool to use on the clips but it's gone who knows where. Just insert and push. Clips come right out. Why is it you only lose the tools that can't be replaced?
B Excessively Tight Steering Austin Healey 19
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
S TR2/3/3A OMG problem—the doors are too tight Triumph 12
T TR5/TR250 Wiper wheel box knurled end not tight on arm Triumph 9
maxwedge5281 steering tight in center position of steering wheel Austin Healey 2
Got_All_4 TR6 TR6 engine rebuild. Too tight? Triumph 23
L Tight spot on steering box is way off Austin Healey 18
P TR6 tight suspension Triumph 4
TomMull TR2/3/3A New Top Too Tight Triumph 14
Martinld123 Grease Retaining Cup Not Tight Fit Austin Healey 2
wkilleffer MGB Fitting a new top to a 74 MGB- how tight is too tight? MG 23
A rear brake drum too tight after rebuild Austin Healey 3
M General Tech Knockoffs way to tight Triumph 16
Joe Reed General Tech Starting a screw in a tight location... MG 9
KVH General Tech Transmission Drain Plug Too Tight? Triumph 5
S TR2/3/3A paint tight spots Triumph 7
M Tight steering. Austin Healey 5
S Eared knock-offs - how tight? Austin Healey 19
DornTRoriginal Is the sprocket on the camshaft supose to fit so bloody tight? Triumph 4
H top trunnion too tight Austin Healey 3
H hood-tight fit-advice please Austin Healey 4
Tinkerman TR 3 Valve Cover nuts - how tight Triumph 13
T TR2/3/3A TR3A tight steering/silent blocks Triumph 8
M Exhaust Clamps a Tight Fit [pics] Triumph 7
G OD of inner spring is tight to ID of outer spring Triumph 3
R Stromberg adjustment screw tight 175CD Triumph 10
F Tight Crankshaft [engine reassembly] Spridgets 45
D How tight should the steering wheel nut be? Triumph 20
S TR2/3/3A tr3 door too tight Triumph 1
Morris Not at all water tight... Spridgets 12
RJS Wire Wheel Knock Offs - How Tight? Triumph 15
PatGalvin Front Suspension Too Tight? Triumph 26
I TR6 TR6 trunion help - how tight, correct lubricant? Triumph 24
1 tonneau too tight Spridgets 19
Atrus Drum brakes too tight? Spridgets 7
SpannerMan Importance of tight dashboard fastenings Triumph 1
john_j Lever for making tight turns? Austin Healey 12
sultanoswing T-Series Removing Rear Hatch - tight screws!! MG 1
L how tight for roll bars? MG 2
M Wire wheels - how tight? MG 3
Patton How tight should the fan belt be? Austin Healey 8
HealeyRick BJ7 Side Window Alignment Austin Healey 7
nichola TR6 Door handle and window crank installation Triumph 0
G For Sale: Triumph TR2, TR3, TR3A, TR3B Factory Steel Hardtop, New Rear window, Partial Bracket Set Triumph Classifieds 2
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
T Early BJ7 Vent Window Seal Austin Healey 2
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 22
B TR4/4A Window Channels Triumph 6
JFS Wedge Door wing window finisher Triumph 2
maxwedge5281 How to replace the rear window in a factory hardtop Austin Healey 8
