Allard1680
I’m rebuilding the drivers side window regulator on a 66 Tiger. Have the regulator repair kit from Sunbeam Specialties. The question I have is about how the torsion spring in the window crank housing holds the “star gear” to the plate on the shaft that the window handles slides onto. When I drilled out the rivets and removed the shaft housing I could hear the spring unwind. Other regulators I have worked with just have the window handle directly attach to the small gear on the regulator.
I’m looking for some guidance on how to hook that spring back up. The directions provided by Sunbeam Specialties does not mention this at all.
Thanks in advance!
Thanks in advance!
