Wanted Two inside window handles & Regulator for Driver's Door - '67 GT
AngliaGT
Need two handles & regulator.
If you have them,let me know how much (including shipping).
AngliaGT
AngliaGT
I need a little more information - is Eric at a parts business,
& where is he located?
Grantura_MKI
As they say now days “recycled”.
Near me … he operates out of his house. I can collect and send if needed?
AngliaGT
AngliaGT
David,
Thanks for the offer,& the information.
I'll contact him when I have the time - working 50 - 60 hours a week.
Grantura_MKI
what are you doing with the rest of your free time?
I have never counted the total number of hours I put in during the week…it would make me ill.
AngliaGT
AngliaGT
Thinking I should be working on the GT,the Miata, & the Dakota.
I took a vote,but Apathy won once again.Besides,it's really cold down
there in the garage right now.
T TR2/3/3A rings inside bevel Triumph 2
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
Chuck9482912 Letters Cast Inside Engine Block Austin Healey 0
luke44 TR2/3/3A TR3 inside the tires track dimension Triumph 5
tr6nitjulius Oil flow view inside operating engine Other Cars 4
D What's inside the gas tank?? Spridgets 13
C Inside Door Handle Austin Healey 5
J Flaking Paint Inside Differential Austin Healey 6
S TR2/3/3A rubber seal go towards the inside of the trunk Triumph 3
FlyingCat Spitfire Inside door handle Triumph 2
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
L 100 ID plate inside cockpit Austin Healey 10
G TR4/4A Inside Windscreen Capping Triumph 6
T Frame: Inside Treatment? Austin Healey 8
DornTRoriginal TR2/3/3A Water Inside the Engine Triumph 11
DornTRoriginal TR2/3/3A Water Inside the Engine Triumph 4
RickB MGB Rain water getting inside behind dash MG 17
J BJ8 Inside Top Door Rails-How Attach? Austin Healey 6
M TR4/4A Position of wiring loom inside the trunk/boot area. ? Triumph 3
max71 MGB Here's what the inside of a MGB mechanical gauge looks like MG 0
M BT7 Inside Threshold Plates Austin Healey 1
B Replacement of Small Black Wire inside Distributor Austin Healey 15
Jim_Gruber Painting inside a BE Boot Spridgets 8
Simmo MGB Have you ever tried removing the spring clip on the Keylock from inside the door MG 0
J Outside door handle opens but not inside Austin Healey 2
BoyRacer thermal barrier on inside of firewall Austin Healey 6
D Inside the frame rails Austin Healey 14
A TR2/3/3A TR-3A post 60K inside trunk latch photo Triumph 4
K Rough patch inside bore of SU? Triumph 2
P Odometer Finger Prints inside glass Triumph 9
T TR2/3/3A Peak inside the TR3 sill Triumph 8
R fuel tank cap., anything inside displacing volume? Spridgets 3
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
H inside of wings question Austin Healey 7
arizonamike TR5/TR250 TR250 Inside Rear View Mirror Mount. Triumph 2
wangdango inside of body panels? Austin Healey 10
TraceZ Our sprite is ALIVE - video inside!! Spridgets 7
M Help - inside my distributor Austin Healey 5
H filters inside of BJ air cleaner? Austin Healey 24
AUSMHLY Inside the car Blind Spot Mirror - MacGyvers back! Austin Healey 61
K TR4/4A Exterior of TR4 gas tank...inside OK Triumph 3
I Source for ribbed material for inside bugeye door? Spridgets 5
M Spitfire RARE BL Spitfire parts catalog see inside Triumph 0
T TR2/3/3A TR3 inside door linkage Triumph 8
eschneider help - points / contacts inside wiper motor ?????? Triumph 9
aeronca65t inside pass Spridgets 9
livinginthepast BE bodywork question - inside/fwd hood brace[?] Spridgets 17
T TR2/3/3A TR3 diff color -inside Triumph 27
