Vacume gauge reading on servo line
Jerry
I am about to send off my brake servo for repair but tested the vacume at the servo line. The reading was 11-14 at 1500 rpm. Is this normal and would it operate a functional servo?
Jerry
BJ8
22A servo
PS non calibrated, cheapo, vacume gauge
Keoke
Yes that is about it for the Healey. My tests show the stock boodter will operate with as little as 3. However, the test you performed does not exonerate a booster failure. If it fails to work send in for a repair.
Genos2
I'd check vacuum at the manifold for a reference.Myself, I'd like to see 16-18 inches. Of course timing & cam specs can make a difference. I can't remember if there's a check valve or not, it would be easy to install one, come to think of it there may be a metal one in line by the firewall.I'll look in workshop manual tomorrow. cheers Genos2
J
Jerry
The unit is all boxed up for UPS to go for repair. I took the cover off the vacume chamber and it has new parts inside. So someone did a bad rebuild. I must say once the fender is on, that unit is much harder to remove.
I also forgot to ask. I don't have the one way valve in the vacume line. Does Power Brake Exchange sell them?
Now back to adjusting the carburators! Idle is still too high.
Thanks for your help.
Jerry
BJ8
Keoke
Well the one way valve on a stock booster is the first fitting at the top that the Vacuum line attaches to. Should it be missing a valve can be purchased at most auto stores and installed in the Vac line, However a missing valve should be felt on the brake pedal as a pulsation. and there would be no braking after the engine is shut off.
andybj8
As Keoke says, the one way valve is screwed into the ali housing and the hose attaches to the union end, its shown in this view as the union sitting in the piston.
https://www.austin-healey3000.com/apps/photos/photo?photoid=5130998
Note that on some Girling mk2a servos (fitted to other cars)that this union was a straight thru peice (not a NRV), to check unscrew it and blow thru it to see if it only lets air one way, otherwise you can buy even the original item or one that fits in between the hose.
ps you can also see the union/ one way valve in this page (servo installed), without the hose attached to it:
https://www.austin-healey3000.com/brakes.htm
cheers Andy
J
Jerry
Ok, I have a one way valve on the servo, so I don't need that. I wondered if the grafite lubrication that was used in the container was too thick to allow movement. It felt more like a very thick grease. Either way, the Power Brake people should be able to fix it.
Jerry
GregW
Platinum
It probably was grease. The rebuild kits these days come with that. If you DIY and want dry film, you need to purchase that separate.
longbridgehealey vacume leak somewhere Spridgets 7
J vacume lines MG 3
TypeRboy Headlamp vacume valve.. Lotus 6
J For Sale Gauge brackets (lot of 7) for sale Other British Classifieds 0
Rick_Thompson TR2/3/3A Overheat issue, gauge adjustment Triumph 9
G MGB ugh.....the fuel gauge went to *** again! MG 8
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
roscoe Fuel Gauge Austin Healey 0
G Smith's temp gauge repair Restoration & Tools 4
CARSINC eBay Gauge Packages Spridgets 6
Gliderman8 TR6 Excessive reading on volt gauge Triumph 17
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
Gatheringtree TR2/3/3A Gauge Set Triumph 17
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
LD-Ordie TR2/3/3A TR3 gauge service Triumph 11
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
B For Sale BaulyCars - Gauge Bezels Triumph Classifieds 0
AngliaGT MGB-GT Gauge Repair Recommendations? MG 4
BierRunner TR6 Temperature Gauge Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
Lairhead52 Wanted Oil Press Gauge Triumph Classifieds 0
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
Fanch00 Inoperative Fuel Gauge Austin Healey 10
R Coolant temperature gauge Spridgets 8
EWD TR6 Temp Gauge - 74 TR6 Triumph 11
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
Editor_Reid Water Temp Gauge Austin Healey 5
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
E Gauge Lights Austin Healey 4
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
R TR2/3/3A Fuel Gauge Triumph 19
nichola TR6 Smiths volt gauge needle barely moves Triumph 25
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Fuel gauge calibration procedure Austin Healey 18
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
