TR2/3/3A TR3 motor mounts
JPeter
Member
Can the Motor mounts on a TR3 be changed without removing the engine? Will the tranny hit the firewall before the mount studs are clear? I have the upper and lower A frames out now and I will be taking the apron and radiator out to install a yellow fan and I would like to change the mounts if I could. Thanks
Banjo
Yes. It's not that big of a deal. they come out fairly easily. Just make sure to re-attach the ground strap on the drivers side.
jsneddon
Yup - I concur with Banjo. I replaced mine without removing anything at all.
Plenty of room to jack up the motor and get them out.
Geo Hahn
If you intend to keep a crank hole and use a crank you may want to pay attention to any shims you find with the old mounts and how the crank hole lines up with the starter dog with the new mounts.
R TR2/3/3A TR3 Wiper motor Triumph 10
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
S TR2/3/3A When lifting the tr3 motor Triumph 10
NutmegCT TR2/3/3A TR3 - Motor Trend magazine, 1956 Triumph 2
S TR2/3/3A grease in tr3 D2 wiper motor Triumph 2
S TR2/3/3A color of tr3 D2 wiper motor Triumph 5
S TR2/3/3A Wiper motor brushes tr3 Triumph 2
S TR2/3/3A wiper motor tr3 Triumph 4
S TR2/3/3A new tr3 motor Triumph 7
T TR2/3/3A How do I remove fan on TR3 heater motor? Triumph 6
B TR2/3/3A TR3 motor mount Triumph 9
tinman58 TR2/3/3A How to break in a TR3 motor Triumph 7
ekamm TR2/3/3A tr3 motor mount Triumph 5
mgedit TR2/3/3A Wiper Motor Bracket for 56 TR3 Triumph 9
C TR2/3/3A TR3 w/motor swap FS Triumph 14
PatGalvin TR2/3/3A TR3 Shifter and Motor Mount Support Ques... Triumph 7
K TR4/4A Putting aTR4 motor and trans in a TR3 Triumph 4
B TR2/3/3A tr3 or 4 motor? Triumph 16
mountainman TR2/3/3A TR3 Wiper Motor Triumph 4
mountainman TR2/3/3A TR3 Wipper Motor Wiring Triumph 4
P TR2/3/3A tr3 wiper motor mounting Triumph 7
mountainman TR2/3/3A TR3 Windsheild wiper Motor Question Triumph 4
Got_All_4 TR5/TR250 Switching a TR3 wiper motor over to a TR250 Triumph 4
Tinkerman TR2/3/3A Reasembly of Starter motor, TR3 Triumph 4
Moseso TR2/3/3A Deep in the TR3 motor Triumph 12
K TR2/3/3A Torqing the head again?....rebuilt motor... TR3 Triumph 4
M TR2/3/3A TR3 Wiper Motor Rebuild Triumph 8
martx-5 TR2/3/3A TR3 Wiper Motor Triumph 3
C TR2/3/3A Motor and Trans Out!!! TR3 shift lever??? Triumph 6
gsalt57tr3 TR2/3/3A TR3 Windsheild Wiper Motor Triumph 7
J TR2/3/3A TR3 fan and motor mount R&R Triumph 4
