TR2/3/3A How to break in a TR3 motor
tinman58
With only 8 miles on the new motor, We participated with our local TRIUMPH CLUB on the Polar Bear run. We left Brentwood for the start of the drive in Woodside at Buck's cafe. After meeting up with about 12 other members and their rides (we even had a porsche carrera in our group! From Woodside we followed route 35 up to Pacifica. The weather was beautiful, Bright and sunny! We headed down hwy 1 past devil's slide and thru Half Moon Bay. We stopped at a very nice spot to take some photos of the Tr's with the ocean in the back ground. From there we headed south to Davenport for lunch. Some of our group went up the mountian to a winery for some tasting. Glen and I headed south to Santa Cruz where we got quite a few thumbs up. Then back home to Brentwood. All total 260 miles on the odometer. The engine ran perfect. The hardest part of the drive was that I wanted to put my foot down to see how the 89m.m. pistons and the supercharger will do. Another 300 miles for breakin and then.......What a awesome day and what awesome people and very nice cars. The red Tr is Glen's very nice TR3( the one he let me drive up the delta a couple weeks ago)
G
I understand the object of your post being the fun of the trip,but just out of curiosity,what type and brand of oil are you using in your new engine during break in?
DougF
Sounds like a fun drive. Sounds like even more fun in a few hundred miles.
tinman58
tinman58
I am using castrol 20-50 plus a zzdp additive for the first 500 miles.Then amsoil 20-50.
G
I imagine that the Cstrol is a regular blend. Is the Amsoil regular or synthetic?
tinman58
tinman58
Yep the Amsoil is 100% synthetic
G
You might want to run the regular Castrol to about 3000 miles to properly seat the rings. Synthetic oil is great for keeping long term wear down,but it's so super slipperly,it might keep the rings from properly seating and lead to higher future oil consumption. Just my thought. Enjoy your car. Im sure others will chime in.
Scotsman TR2/3/3A Flushing break lines on TR3 Triumph 3
D TR2/3/3A TR3 break light switch. Triumph 23
Carlbanan56 MGB MGB rear break rebuild MG 6
D Back on the Midget after a vacation and work break. Spridgets 48
M Wedge TR7 break fluid Triumph 7
D Made a sheet metal break. Restoration & Tools 5
Gliderman8 Lights don't break FORUM Navigation Questions 23
D After a long break.... Spridgets 6
BN6_2197 Adjustment of hand break BN6 Austin Healey 2
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
steveg Break In procedure Austin Healey 5
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
Scotsman TR2/3/3A Drum break turning specifications Triumph 2
Rut Engine break in Spridgets 4
BN6_2197 Removing Break Fluid from Bn6 Austin Healey 13
jlaird What is Bugeye master break painted with. Spridgets 4
SwamperCa General MG Lifter break-in MG 14
Boggsy64 MGB Semi metallic disk brake - break in MG 10
D break in engine Austin Healey 6
Scotsman Shimming Break Callipers Triumph 3
Scotsman break line compatibility with old connections Triumph 1
Scotsman "Coffee grounds" in break fluid Triumph 8
L Engine break-in period Spridgets 6
Sopwith_Camel long break Jaguar 7
J Dunlop L Racing Tire "Break In"? Racing 9
RJS Water Pump Break-In Triumph 10
M Checking rear break drums and pads Triumph 7
M Break problem Other British Cars 8
bigjones Another embarrassing break down Spridgets 24
tahoe healey Hand break - broke Austin Healey 8
doughairfield Oil during engine break in Triumph 6
chicken Tips for getting the paint break line right Austin Healey 18
K Memory Refresh:What oil to use after break-in? Triumph 1
VelodromeRacer Engine break in? Racing 1
JPSmit Spring Break Accessory Spridgets 0
2wrench Miles to drive for break-in Triumph 4
Stewart So whats going to break next? MG 10
Geo Hahn TR4/4A Bad Break - Ouch! TR4 Fan Triumph 11
2wrench Need recollection refreshed on break-in oil. Triumph 8
2wrench Gave you guys a break. Back with a few questions Triumph 13
T Break-in consideration for the new 4.0 heads? Triumph 3
PATR8 break down of what other forums are talking about Triumph 2
N How much oil should an engine use on break in Triumph 20
John_Mc Does it count as a break down? Triumph 14
beachbumbarry T-Series MGB break / clutch masters in MG-TD MG 2
N Break In Woes Part 2 Triumph 3
N Break In woes Triumph 8
healeyboz Break in tighten up Spridgets 4
Brosky Break in oil, normal driving oil......thoughts?? Triumph 43
G So why did the blade break? Restoration & Tools 11
