break line compatibility with old connections
Scotsman
Going to be replacing break lines etc in my tr3 with 90% copper/10% nickel lines as supplied by moss. Is it OK to reuse the old 3 and 5 way connections in the front and back. I know in plumbing there is an issue with electrolysis when attaching copper to iron pipes.
TR3driver
Great Pumpkin - R.I.P
Should be OK, but of course there is no substitute for careful inspection when working on 50 year old braking systems. The original lines were plated to prevent corrosion.
chicken Tips for getting the paint break line right Austin Healey 18
Carlbanan56 MGB MGB rear break rebuild MG 6
D Back on the Midget after a vacation and work break. Spridgets 48
M Wedge TR7 break fluid Triumph 7
D Made a sheet metal break. Restoration & Tools 5
Gliderman8 Lights don't break FORUM Navigation Questions 23
D After a long break.... Spridgets 6
BN6_2197 Adjustment of hand break BN6 Austin Healey 2
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
steveg Break In procedure Austin Healey 5
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
Scotsman TR2/3/3A Drum break turning specifications Triumph 2
Rut Engine break in Spridgets 4
BN6_2197 Removing Break Fluid from Bn6 Austin Healey 13
jlaird What is Bugeye master break painted with. Spridgets 4
SwamperCa General MG Lifter break-in MG 14
Boggsy64 MGB Semi metallic disk brake - break in MG 10
Scotsman TR2/3/3A Flushing break lines on TR3 Triumph 3
D break in engine Austin Healey 6
Scotsman Shimming Break Callipers Triumph 3
Scotsman "Coffee grounds" in break fluid Triumph 8
L Engine break-in period Spridgets 6
Sopwith_Camel long break Jaguar 7
J Dunlop L Racing Tire "Break In"? Racing 9
RJS Water Pump Break-In Triumph 10
tinman58 TR2/3/3A How to break in a TR3 motor Triumph 7
M Checking rear break drums and pads Triumph 7
M Break problem Other British Cars 8
bigjones Another embarrassing break down Spridgets 24
tahoe healey Hand break - broke Austin Healey 8
doughairfield Oil during engine break in Triumph 6
K Memory Refresh:What oil to use after break-in? Triumph 1
VelodromeRacer Engine break in? Racing 1
JPSmit Spring Break Accessory Spridgets 0
2wrench Miles to drive for break-in Triumph 4
Stewart So whats going to break next? MG 10
Geo Hahn TR4/4A Bad Break - Ouch! TR4 Fan Triumph 11
2wrench Need recollection refreshed on break-in oil. Triumph 8
2wrench Gave you guys a break. Back with a few questions Triumph 13
T Break-in consideration for the new 4.0 heads? Triumph 3
PATR8 break down of what other forums are talking about Triumph 2
N How much oil should an engine use on break in Triumph 20
John_Mc Does it count as a break down? Triumph 14
beachbumbarry T-Series MGB break / clutch masters in MG-TD MG 2
N Break In Woes Part 2 Triumph 3
N Break In woes Triumph 8
healeyboz Break in tighten up Spridgets 4
Brosky Break in oil, normal driving oil......thoughts?? Triumph 43
G So why did the blade break? Restoration & Tools 11
J Engine Break In Procedure? Spridgets 12
