I have had the opposite problem, mine is to lean.
I did a leak down test with my homemade unit. It seemed to give uniform results across all cylinders. applied 80 psi and leak down was 72 psi.
Warm compression test was 115, 117, 110, 115, 117, 120 PSI and with oil 125, 124, 125, 127, 125, 125 psi. Does this seem low for a stock engine? it's a 1974 almost 1975.
I will call my machinist tomorrow and see what he says.
I drove it very easy, not over 3k rpm for the first 600 miles, then changed the oil to the Rotella 10W40 and started working it up. I did not do 5k till it had around 1400 miles on the rebuild.
I also used the ZDDP in the first two oil changes.
It now ready for the third.
