TR5/TR250 Torque setting for TC2500 head
Wombat
Member
Hi, What is the correct setting for the cylinder head bolts on a TC2500? What is the correct tightening order? Thanks!
piman
Hello Wombat,
the torque setting is :- 65lb\ft 9Kg\M.
11 7 3 1 5 9 13
No6 No1
14 10 6 2 4 8 12
Alec
britishcarfreak
You're bound to find a manual cheap somewhere.
If you're stuck there's a place called the imperial book shop in hobart that have two copies at present 15-20 dollars AU each.
They could post you one.
Also check your state library ours has heaps of car manuals.
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
S Torque setting for U-Bolt nuts Austin Healey 12
T Torque setting on brake rotor Triumph 4
M TR2/3/3A Torque setting question for TR3 Triumph 12
T TR2/3/3A tr3 steering box drop arm nut torque setting? Triumph 2
livinginthepast Is there a torque setting for this? Spridgets 2
H Crankshaft nut torque setting Austin Healey 16
letemglow Torque setting of rear hub nut Austin Healey 24
M Torque Setting for Lugs? Spridgets 7
Michael Oritt Winner's Circle hub-nut torque setting Spridgets 17
G TR6 Crank Bolt Torque Setting on Aluminum Flywheel-TR6 Triumph 17
A TR6 Need a torque setting for rear axle?? [TR6] Triumph 1
I Torque setting for BN1 Cylinder head Austin Healey 2
O MGB-GT MGB/GT Front Sway Bar Torque Setting MG 20
Carlbanan56 MGB Rear axel torque? MG 4
C Steering Arm Castle Nut Torque Austin Healey 5
P TR2/3/3A British High Torque starter Triumph 6
B Head Re-Torque Austin Healey 8
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
W TR2/3/3A Differential cover torque Triumph 4
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
M High-Torque Starter Austin Healey 10
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
B High-Torque Starter Rattling Noise Austin Healey 3
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
Lin Oil sump torque value? Spridgets 3
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
D Torque Sticks Restoration & Tools 6
J TR2/3/3A Head Torque - Wet or Dry Triumph 6
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
R Our J-H plan - torque specs needed! Other British Cars 2
S Locknut - rear wire wheel - torque spec? Austin Healey 15
S TR2/3/3A Torque specification on large pitman arm nut Triumph 1
Michael Oritt Torque values needed for 100 Austin Healey 5
R General Tech Crank bearing cap broke...Torque?? Triumph 37
G Torque for Front Pinion Nut Austin Healey 3
D torque values Austin Healey 2
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
Jim_Stevens TR2/3/3A Axle to leaf spring torque Triumph 2
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
G TR4/4A ARP Bolt Torque Specs Triumph 10
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
