suspension upgrades
philman
What kind of suspension upgrades would be nice on an MGB as a fast road car? My brother will want to know for his B when I get the engine in.
Steve_S
Polyurethane bushings and good tires will make a world of difference. If it's a rubber bumper car, lower it to chrome bumper height.
Some people will tell you to uprate the sway bar, lower the car more, run stiffer shocks, etc. These can make an improvement but aren't always good for road use. I'd take it one step at a time so you can see the difference each part makes. Since there is no "best setup" for everyone, tailor the car to its driver instead.
philman
philman
Thanks, I looked at the car and probably all he would want arre new bushings. The suspension seems really tight. It hasn't been driven in about 5 years and hasn't run since the "new" engine was installed.
vping
Bronze
I agree with Steve as well and can't wait to do it to my car. New tires already installed and Urethane bushings are on the way. Once I get it on the road I will try it with the stock sway bar and then increase from 9/16" to 5/8".
Nunyas
I'd like to add that if the car falls into the years between (and including) 1974.5 - 1976 then you will want to ADD a front sway bar, because the MGB's during those years had NONE in stock form. Soooo, "early" RB B's should be lowered, have a stock CB sway bar added to the front end, and swap the bushes for poly. Those three things will make the car handle like a completely different car.
Of course, adding a sway bar to a RB B from those years makes a world of difference to begin with...
vping
Bronze
What are the forums thoughts on a Rear sway bar?
1965_MGB
I have read that rear bars on CB cars can cause some problems during hard cornering. Most just suggest upgrading the tiny front bar, but leave the rear bar out.
The later RB cars have one, and probably should retain it due to the higher center of gravity.
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
F For Sale suspension upgrades TR6 Triumph Classifieds 0
W TR2/3/3A TR2/3 Front Suspension Upgrades Triumph 13
Kirk_Fisher TR4/4A TR4 handling/suspension upgrades Triumph 19
HealeyPassion My BJ7 suspension upgrades Austin Healey 13
Tabcon TR4/4A TR4 Rear Suspension Upgrades Triumph 15
K TR2/3/3A TR3 alloy wheels and Front suspension upgrades Triumph 14
R early 87 jaguar xjs suspension upgrades Jaguar 2
Timd Midget Suspension Upgrades Spridgets 27
EMGEBE MGB MGB Front suspension upgrades????? MG 6
T C Suspension upgrades MG 6
M TR2/3/3A Rebuilding suspension Triumph 29
K TR6 Rule of thumb for frt suspension shims Triumph 6
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
Racer-X- Special Suspension tools 18G95 and 18G78 British Motor Corp 1
P Suspension upgrade for a A40 Devon. British Motor Corp 0
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
L TR6 MII Suspension Triumph 6
R TR6 Rear suspension droop restraint Triumph 0
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
Healey Nut BT7 Rear Suspension Austin Healey 15
D MGB Rear Suspension Damper Link Arm MG 2
R TR6 Front suspension fulcrum pins Triumph 6
Michael Oritt Evaluating Suspension Components Austin Healey 4
Upland Mark IV front suspension Spridgets 3
JPSmit Suspension question Spridgets 1
S TR2/3/3A Front Suspension Triumph 6
J Front Suspension Rebuild Austin Healey 16
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
EWD TR6 74 TR6 - suspension bushing tightening Triumph 1
M TR6 suspension puzzle Triumph 3
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
L 100/6 tuning and suspension ugrades advice Austin Healey 7
F TR4/4A Front Suspension Triumph 3
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
bugedd Winter Suspension Project Spridgets 7
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
M Creaking rear suspension Austin Healey 13
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
S TR4/4A Coil-over suspension upgrade Triumph 4
P TR6 tight suspension Triumph 4
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
HighAltitudeTR3 TR2/3/3A Saggy suspension? Triumph 5
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
S TR2/3/3A Suspension Rebuild & Steering Box Triumph 4
