survey question
Guinn
150,150,150,150. Stock engine, Speedo reads 27600 but it is probably 127600. No history on the engine. May have been rebuilt for all I can find out.
Guinn
Platinum
I'm out:
What's "stock?" /ubbthreads/images/graemlins/wink.gif
Guinn
Stock? How about "unmolested"? Like from the factory. heck, I don't know! /ubbthreads/images/graemlins/crazyeyes.gif
Guinn
Nunyas
we have car molesters in our midst?!?
should I be afraid? /ubbthreads/images/graemlins/lol.gif
John Moore
I think I had around 165 across the board. It's not important so much what the guage reads, as much as there is not more than a 10% difference between the cyclinders.
Guinn
Yeh, we got car molesters. Like the ones that put a 10 cyl Ford or Dodge in an MGA! I think maybe it was Jarrod down under that sent me a picture of an A with this HUGE engine that might have been a 10 cylinder. Awesome.
Guinn
Nunyas
10 cylinder? /ubbthreads/images/graemlins/eek.gif I think they'd have to change so much of the car to make that work that I wouldn't consider it an MG anymore. heh
HealeyPassion Survey of Ruddspeed valve covers Austin Healey 37
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
Pythias Spin On Oil Filter: Survey Says? Spridgets 20
mountainman TR 3 with Plastic Surgery Survey Triumph 13
AUSMHLY Survey - stock, hybrid, aftermarket steering wheel Austin Healey 37
zimmy shocks or levers "survey" Spridgets 44
JPSmit survey says Spridgets 11
T Survey - and be honest now... Triumph 15
jerrybny TR6 TR6 Engine Temp survey Triumph 22
Morris Spridget EFI survey Spridgets 11
G Roll Bar survey Triumph 7
G Navigation system user-survey Restoration & Tools 1
jlaird Golden Jubilee survey Spridgets 31
rick_ingram Interesting Marketing Survey for the New MG MG 34
AUSMHLY Clutch in or out at stop - survey Austin Healey 32
Simon TR4a Spitfire Survey of Spitfire owners for article. Triumph 12
jcatnite Survey of spridget radiators Spridgets 4
tony barnhill AARGH! & A SURVEY MG 55
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
