Shifter
paulking
Hi im new here and i did the introduction.Im wondering if i could get some help.I just bought this MG and the shifter rattles quite a bit around 50 miles per hour ,is there a fix for this or will i just have to live with it.Thanks for any help
Paul
WELCOME TO THE FORUM!! sorry about the caps, its a hazard of working with excel....
If your shift nob is of the replacement type ..they have been known to rattle with a sort of a buzzing noise. Could also be the shifter bushing is worn or missing. This would be evident with a rather sloppy shifter.
m
Platinum
The nylon bush at the tranny end of the shift lever is the most likely culprit.
JPSmit
Welcome, where in Canada?
bob67bgt
If the car is a 68 or newer MGB there is also a anti rattle spring and plunger located at the shifter ball. Many are missing and need to be fitted. Also I agree with the aftermarket shift knob and nylon bushing issues. Bob
JPSmit
paulking said:
I live just outside of Windsor
Still far away, :frown: I am in Toronto. Do you come to Bronte for British car Days?
drooartz
Welcome aboard! My MGB came from your area, bought it about a year ago.
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
S 1993 dodge Dakota shifter Other Cars 9
KVH General TR Shifter Stuck Triumph 6
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
B MGB 1977 MGB Battery Box and Shifter knob MG 4
V GT6 Shifter Worn? Triumph 2
dbenichou289 TR2/3/3A Shifter knob jam nut Triumph 2
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
66healey BJ8 shifter spring install Austin Healey 2
VelodromeRacer BJ8 Shifter reinstall Austin Healey 4
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
Rut Bugeye shifter cover [top hat] Spridgets 6
W General TR Shifter Question Triumph 16
S Shifter Bushing Question Austin Healey 2
P Shifter Spridgets 3
T Shifter Cupola for Datsun 5 speed Spridgets 19
D TR4/4A shifter anti rattle pin Triumph 2
T Modified BE Shifter Cupola for Datsun 5 Speed Spridgets 7
P Is my shifter bushing missing? Austin Healey 25
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
Got_All_4 General TR Tranny Fork alinement problems & TR3 shifter in a TR6 tranny Triumph 17
maxwedge5281 center shift transmission shifter Austin Healey 3
S TR2/3/3A this shifter/ ball and cup Triumph 5
M TR2/3/3A Gear Shifter Maintenance?? Triumph 3
6 Shortened shifter? Spridgets 9
P TR2/3/3A TR3 shifter popping out of selector shaft Triumph 10
KVH The Shifter Again--and I'm Stuck Triumph 10
AHS TR2/3/3A TR3 transmission clutch fork & shifter removal? Triumph 5
KVH My Shifter is Stuck Triumph 10
bugedd Shifter boot Spridgets 18
F TR4/4A TR4 shifter and transmission tunnel Triumph 4
64rocksprite Datsun 5 speed bronze shifter bushings Spridgets 3
M Spitfire Need '75 to '80 Spitfire overdrive shifter Triumph 2
T TR4/4A my bad- need tr4 shifter photo Triumph 12
Got_All_4 Wedge TR7 rubber 5 spd shifter boot Triumph 6
Rut 5 speed shifter bushings Spridgets 8
S "Buzzy" shifter handle... MG 2
B Datsun transmission shifter levers- Spridgets 16
rlich8 Thread for Shifter Triumph 5
drooartz Floor mats and shifter Spridgets 1
jjbunn E-type Series 2 PRNDL shifter ID plate and parts Jaguar 0
69sprite rubber shifter boot won't stay Spridgets 8
PatGalvin TR2/3/3A TR3 Shifter and Motor Mount Support Ques... Triumph 7
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
J Recovering AH shifter dome with leather cloth Austin Healey 16
M Toyota 5 speed Shifter Austin Healey 2
A sloppy shifter !! somthing must be wrong Triumph 7
A shifter knob with lift on the face ? Triumph 5
Gliderman8 5-Speed Conversion - Shifter Triumph 10
