TR2/3/3A Setting ignition timing at 8 degrees BTDC instead of 4?
Geo Hahn
Since I set the final timing by driving and listening for the pinging -- I'd say they perform best wherever they perform best. But I start with 4° static timing.
Lots of variable here, both in the engine and at the pump, but 8° static sounds like a lot.
trrdster2000
Good advise George, setting these engines to perform at peak output for normal street driving can start a continuous tinkering to maintain such and adds a lot of stress on all the parts. Even race engines don't last 500 miles all the time and surely they are put together with closer attention to detail than we can get on our tracker engine.
Wayne
K
karls59tr
Bronze
So is this the way to "road time" the engine after the initial 4*setting: drive in top gear around 30-50mph and if there is pinging Retard the knob on the vac advance one degree and test again and keep doing this until there is no pinging?
martx-5
Basically that's how you do it, but after the initial 4° setting, you probably won't get any pinging. In that case advance the knurled knob until you do, and back off enough for it to go away. If you initially set the static timing at TDC with the longest hash mark (the one in the center of the vernier), then when you advance the knurled nut two more marks (supposedly 1/2 turn), you'll be at 4° BTDC. Then any changes you make will be easy to keep track of.
K
karls59tr
Bronze
I found the article I mentioned at the beginning of this thread. It's at "TR Ignition Timing-VTR" and the article is by Ken Gillanders. He sets the timing using the static method with test bulb and when you turn the crank in a clockwise direction you place the hole drilled in the rear half of the pulley 3/8" to the left of the timing pointer. Turn distributor till test light come on etc. Then he says: "3/8" measured on the circumference of the crankshaft is about 8 degrees,which is more initial advance than the factory recommends,the engine however seems to run more effectively at 8 degrees than 4 degrees of advance". Also does each notch on the vac advance vernier represent 4 degrees?
martx-5
...,the engine however seems to run more effectively at 8 degrees than 4 degrees of advance". Also does each notch on the vac advance vernier represent 4 degrees?
You know, each notch may be 4°. It might be 2° of rotation on the dizzy, which may be 4° on the crank. I've always used each notch to represent 2°, so maybe I've always wound up at 8° and it seems to run good with out too much more adjustment.
K
karls59tr
Bronze
You know, each notch may be 4°. It might be 2° of rotation on the dizzy, which may be 4° on the crank. I've always used each notch to represent 2°, so maybe I've always wound up at 8° and it seems to run good with out too much more.
Art Could you clarify something for me. I see how you set your timing and will probably do it that way. Is setting it by having the hole 3/8" before the pointer,as KG describes, doing the same thing?.....in other words that would set timing at 8 degrees without having to use the vernier initially? Then you could road tune for pinging and dial in the vernier.
martx-5
It's six in one hand, half a dozen in the other. I use the vernier as a point of reference. If I start with the long hash mark at the TDC position, it's always just a matter of how many marks are are away from it. I can always go back to the long TDC mark if for some reason things aren't working out and start over. Since Lucas provided that nice little feature, why not use it?
BTW, make sure that your points are correctly set before you do any of this.
K TR2/3/3A Setting ignition timing to 4 degrees BTDC? Triumph 1
petnatcar How to find the perfect ignition setting? Austin Healey 6
B TR4/4A Some Help with Setting Distributor Triumph 47
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
C MGA Setting a 123 distributor MG 0
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
B Front Wheel Camber Setting Austin Healey 8
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
A Setting Camber Really Off Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
HealeyRick Why Setting an Auction Reserve is Important Spridgets 2
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
steveg Carb float setting tool Austin Healey 11
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
S Torque setting for U-Bolt nuts Austin Healey 12
K TR2/3/3A More on setting the timing... Triumph 12
bugedd Setting Timing Spridgets 6
F Problem setting timing on my BT7 - maximum distributor rotation reached Austin Healey 14
mgedit TR2/3/3A Setting Valve Lash Triumph 14
GTP1960 TR2/3/3A the value of experience when setting timing on a modified engine Triumph 33
C TR2/3/3A Dwell setting Triumph 11
Jim_Stevens TR2/3/3A OD low pressure vs Operating valve shaft setting Triumph 9
S Procedure for setting and tuning HD8s? Austin Healey 10
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
S Idle Speed Setting versus Generator Output Spridgets 3
Scotsman TR2/3/3A Setting valve clearance on tr3 Triumph 10
R Question on establishing a baseline timing setting Triumph 3
T Torque setting on brake rotor Triumph 4
B Setting door glass Austin Healey 3
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
Gliderman8 TR6 Setting TR6 valve clearances Triumph 19
R TR4/4A Tr4a, Stromberg float setting Triumph 6
M Carburetor tuning - setting mixture Triumph 6
C Setting bonnet height at front? Austin Healey 8
T Setting up the diff carrier's gears questions?? Triumph 3
pkmh Setting Timing Mark For BJ8 Austin Healey 9
B TR4/4A TR4 ZS carb air/fuel initial setting procedures Triumph 9
rlich8 TR4/4A A baseline setting on TR4A carbs? Triumph 2
J Setting Timing with a Petronix System Triumph 4
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
M TR2/3/3A Setting the timing on TR3 Triumph 48
B TR2/3/3A 57 TR3 TS19009 setting the body to the frame Triumph 3
G Setting mixture on HS4 carbs MG 30
T HS6 idle setting Triumph 3
T H6S float setting Triumph 1
