How do you set the timing when there is a Petronix system? Can I just put the Timing Light on the first spark plug and look for TDC at 4 degrees off? Also, I noticed that the light does not always flicker, at times it will skip. Does that mean I have a miss to the spark plug #1? New rotor, wires and cap will fix that?
