Setting Timing Mark For BJ8
pkmh
Hi All!
Simple technical question and if anyone dares to answer, I would appreciate it or any input on the topic of timing!
From various sources, the "Strobscapic" setting for the ignition timing of a BJ8 is listed as 15 degrees BTDC at an idle speed of 600 RPM's. This info is listed from the BMC Handbook.
Another source is close by saying it's 16 degrees.
Now before I go any further, I am using the above data to establish the engine timing by advancing the distributor as needed while using a timing gun. So if the data or language I am using above is misleading then please advise so as to not confuse the issue here.
But assuming I am making sense so far, then the one degree difference is not so much of a concern to me (or should it be?), but rather what I am curious to know is, when using a strobe or timing gun on the one and only "notch" or mark on the pulley, if that notch is about a half inch away from the fixed point (zero degree mark), what do you suppose that measures in degrees, given a 1/2" away?
Or would one want to take a guess what the distance the pulley mark should be, measured in inches or fractions thereof?
BTW, even if I wanted to further advance the timing closer to the "zero" mark, I cannot for the vacuum advance unit attached to the distributor bumps into the oil filter support bracket adjacent, leading me to believe I'm possibly over adjusting.
Please let me know what you all think about this or ideas on the subject.
Much appreciated!
Paul
Patrick67BJ8
pkmh said:
Hi All!
Much appreciated!
Paul
I use a timing light that I can dial in the 15 degrees and that way I just line up the two marks. If you're using one without this feature then about 3/4" is good. BTW: Sounds like you may have to take your distributor out and turn it one gear notch so it won't hit the oil filter.
Yeah, something isn't right if you are hitting the oil filter if your filter is in the right place. Where on the distributor cap(as you look on a clock)is the #1 spark plug wire?
Invest in an advancing timing light. Best money you will ever spend. I actually run at 18 degrees at 800-900 rpm, vacuum advance disconnected.
TimK
15 degrees is about 4% of 360 degrees. So measure the circumference of the pulley and calculate the distance in inches.
Keoke
TimK said:
15 degrees is about 4% of 360 degrees. So measure the circumference of the pulley and calculate the distance in inches.-------ITS 3/4"--Keoke-- :laugh:
pkmh
pkmh
Hey, thanks Patrick, TimK, Tahoe and Keoke all for the great info and advice (and thanks Keoke about posting pictures from my last post a while back).
To answer Tahoe's question re: "position of the #1 Spark plug wire", I have an old progress photo I took a couple of months ago but which is still accurate at present and you can see enough of the present setup of the distributor cap, the vacuum advance unit and the oil cannister.
Now that I see the position of the #1 wire and subsequently, the positioning of the distributor cap, did I accidentally do a "flip" of the distribtuor cap, or is it still okay to leave the way it is?
Please let me know.
Thanks again all!
Paul
TimK
This is my correctly timed distributor from a different angle. The timing light should flash so that the v in the pulley is 3/4" to the left of TDC.
Paul, you did not mention the model you have. Notice Tim's dizzy sits higher than yours. If you look closely at the wires coming from the dizzy to the plugs, they are in a different order than Tim's. You may be off simply by 1/6 of a firing sequence which would make you have to rotate more than should be to compensate. If I am correct, you just need to switch the wires at the dizzy.
TimK
Tahoe, amazing powers of observation! But that's what you'd expect from an optometrist!
K TR2/3/3A More on setting the timing... Triumph 12
bugedd Setting Timing Spridgets 6
F Problem setting timing on my BT7 - maximum distributor rotation reached Austin Healey 14
GTP1960 TR2/3/3A the value of experience when setting timing on a modified engine Triumph 33
K TR2/3/3A Setting ignition timing to 4 degrees BTDC? Triumph 1
K TR2/3/3A Setting ignition timing at 8 degrees BTDC instead of 4? Triumph 9
R Question on establishing a baseline timing setting Triumph 3
J Setting Timing with a Petronix System Triumph 4
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
M TR2/3/3A Setting the timing on TR3 Triumph 48
C Setting timing. Triumph 18
MTribe setting static timing with pertronix ignitor Triumph 0
wkilleffer MGB Setting the timing on an MGB MG 19
B Setting Timing??? Spridgets 4
A Setting Timing MG 2
A setting timing by ear??? Triumph 9
drooartz Setting timing Spridgets 10
wkilleffer Setting timing on 18GK engine MG 14
G Setting timing without cranking the engine.... Triumph 2
78Z Spitfire Setting Timing on a 1974 Spitfire Triumph 8
G Setting Timing w/o vacumn advance Triumph 6
B TR4/4A Some Help with Setting Distributor Triumph 47
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
C MGA Setting a 123 distributor MG 0
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
B Front Wheel Camber Setting Austin Healey 8
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
A Setting Camber Really Off Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
HealeyRick Why Setting an Auction Reserve is Important Spridgets 2
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
steveg Carb float setting tool Austin Healey 11
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
S Torque setting for U-Bolt nuts Austin Healey 12
petnatcar How to find the perfect ignition setting? Austin Healey 6
mgedit TR2/3/3A Setting Valve Lash Triumph 14
C TR2/3/3A Dwell setting Triumph 11
Jim_Stevens TR2/3/3A OD low pressure vs Operating valve shaft setting Triumph 9
S Procedure for setting and tuning HD8s? Austin Healey 10
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
S Idle Speed Setting versus Generator Output Spridgets 3
Scotsman TR2/3/3A Setting valve clearance on tr3 Triumph 10
T Torque setting on brake rotor Triumph 4
B Setting door glass Austin Healey 3
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
