TR4/4A A baseline setting on TR4A carbs?
rlich8
Hi all,
What would a baseline setting be on TR4A carburetors? For the jets. 12 flats or so?
TR4nut
Thanks to Randall for providing the 4A manual info for the HS6 carbs: its 10-11 flats from the bridge.
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
R Question on establishing a baseline timing setting Triumph 3
B TR4/4A Some Help with Setting Distributor Triumph 47
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
C MGA Setting a 123 distributor MG 0
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
B Front Wheel Camber Setting Austin Healey 8
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
A Setting Camber Really Off Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
HealeyRick Why Setting an Auction Reserve is Important Spridgets 2
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
steveg Carb float setting tool Austin Healey 11
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
S Torque setting for U-Bolt nuts Austin Healey 12
K TR2/3/3A More on setting the timing... Triumph 12
petnatcar How to find the perfect ignition setting? Austin Healey 6
bugedd Setting Timing Spridgets 6
F Problem setting timing on my BT7 - maximum distributor rotation reached Austin Healey 14
mgedit TR2/3/3A Setting Valve Lash Triumph 14
GTP1960 TR2/3/3A the value of experience when setting timing on a modified engine Triumph 33
C TR2/3/3A Dwell setting Triumph 11
K TR2/3/3A Setting ignition timing to 4 degrees BTDC? Triumph 1
Jim_Stevens TR2/3/3A OD low pressure vs Operating valve shaft setting Triumph 9
S Procedure for setting and tuning HD8s? Austin Healey 10
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
K TR2/3/3A Setting ignition timing at 8 degrees BTDC instead of 4? Triumph 9
S Idle Speed Setting versus Generator Output Spridgets 3
Scotsman TR2/3/3A Setting valve clearance on tr3 Triumph 10
T Torque setting on brake rotor Triumph 4
B Setting door glass Austin Healey 3
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
Gliderman8 TR6 Setting TR6 valve clearances Triumph 19
R TR4/4A Tr4a, Stromberg float setting Triumph 6
M Carburetor tuning - setting mixture Triumph 6
C Setting bonnet height at front? Austin Healey 8
T Setting up the diff carrier's gears questions?? Triumph 3
pkmh Setting Timing Mark For BJ8 Austin Healey 9
B TR4/4A TR4 ZS carb air/fuel initial setting procedures Triumph 9
J Setting Timing with a Petronix System Triumph 4
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
M TR2/3/3A Setting the timing on TR3 Triumph 48
B TR2/3/3A 57 TR3 TS19009 setting the body to the frame Triumph 3
G Setting mixture on HS4 carbs MG 30
T HS6 idle setting Triumph 3
T H6S float setting Triumph 1
