rubbing brakes
Atrus
So, recently I replaced both rear brake cylinders. The passenger side was completely blown. The driver’s side seemed to be leaking a bit. The passenger side shoes were totally shot, there was no lining left. On the driver’s side, the top of the shoes were OK, the bottom quarter was severely worn.
So, I replaced the cylinders and put new shoes on. I think the driver drum is ever-so slightly out of round – I can spin the driver’s side and I can lightly hear the shoe brush the drum in one spot. The adjuster is completely backed off, and it really doesn’t drag badly at all, it’s a very light brushing. You don’t see or feel the wheel hang up or anything.
When I drive the car for a very short distance (mile or two), everything is fine. Longer (3-4 miles) I start to hear the shoe squeak intermittently (squeak squeak squeak in a rhythmic pattern) and when I feel the wheels, the driver wheel is very warm to the touch – to be honest, it’s hot.
Any ideas? Is there another adjustment that could be done? I suppose I could try to back off the parking brake a bit to see if it drops the shoe a little more. As I say in all my posts, my goal right now is the drive the car. Next year I plan on tearing it down and going through it. I’d like to avoid getting a new drum right now. I’m also a little curious about the way the shoes were worn badly at the bottom and not at the top.
bugimike
While you may be thinking brakes, this sounds more like wheel bearing symptoms to me. The "intermittent dragging" or "out of roundness" you describe with the brakes does not sound too abnormal. Shoes with the adjustment just backed off do kinda make it sound like something is out-of-round, but this is not necessarily so! The increase in "squeeking" the further you drive tends to sound like bad bearings, especially if the hub gets hot too! Do the brakes start "dragging" the further you drive, or are they just noisier? Of course if lining is totally gone from a portion of a shoe, the metal-to-metal contact will give you a squeek, which should turn into a "grind" when the brakes are applied!
Re-reading you post, an additional problem you may have is how the brake shoes/return springs are installed which could lead to the odd wearing of the shoes!
Atrus
Atrus
Good point Mike, I didn't think of that. I still tend to think brakes because it didn't do this until I did the brake swap.
I have about 20 miles on the car with the new brakes. I'll pull the drum tonight and see how the shoes are wearing. I'm fairly certain the springs and rods are installed correctly, but I'll double check my Haynes manual to be certain.
I don't really feel any additional drag after they are warm.
john_j
When both brakes are off (hand and foot) the handbrake should not be pulling the shoes on at all, so if it's all adjusted properly you won't be able to back it off a bit.
If it's not adjusted properly, than maybe you can.
Quick check - is there some slack in the cable? If it's tight even when the handle is all the way down, then the cable is too tight.
Luke_Healey
The previous owner (or you) may have tightened the parking brake cable to compensate for the wear on the old shoes, so I'd focus my attention there.
However, the rear axles are easy enough to pull out (if your drums come off easily) to examine the condition of the wheel bearings.
Atrus
Atrus
if I pull the axle, do I need to drain the gear lube out of the differential? If not, I'll pull it as well just to be sure.
I did tighten the parking brake cable previously, but I don't think it's too far engaged. The handle still needs to be pulled far to engage it - I was actually considering tightening it up a little more. I'll check it out though, make sure there's some slack in the cable.
Luke_Healey
I pulled mine last night and I had some gear oil come out (I was chasing down a gear oil leak at the axle.) but I don't think it would normally leak out too badly. My rear end is a little low on fluid, maybe 3/8" from the fill hole.
My car didn't have the required paper gasket between the rear end and the axle.
But putting it back together was easy enough.
jlaird
I would expect that the bad drum needs turned, cheep enough.
The metal to metal contact has caused it to get very hot in the past and it cooled out of round.
Turning is a cheep job, have it done and see what you get on that wheel.
bugimike
If brake drag does not increase and the hub does get hot, then I would definitly take a look at those bearings!! Bad bearings can make a variety of deceptive noises that are hard to pin-point, while brakes generally make grinding noises!!
Gearhead
also check that your brake lines are not damaged (smashed shut) alot of tow people just throw that hook over the rear and pull I've replaced too many rear brake lines on Spridgets & B's its very easy to overlook also double check
Atrus
Atrus
Thanks guys...I pulled the drum and looked at the brakes. They seem OK - it almost seems like they are sitting a little low in the drum. I also pulled the axle and looked at the bearing. I was a little surprised to see how easily it came apart! Bearings looked OK I suppose.....I turned the wheel and they seemed good. I think I should maybe pack some grease in there though.
I reassembled and took it for a good 10 mile drive. I heard the squeaking a little, but it's definitely less noticeable than before. The wheel was hot again after the cruise. I'll really have to sit down and look through that entire corner.
As a side note, I didn't hear the brakes rubbing the drum at all anymore. Sounds like you all may be correct in recommending the wheel bearing.
Sarastro
The rear bearings are lubricated by rear-axle oil, so you need not (or, more correctly, should not) grease them. When you pull the axles, you should get at least a little dripping of oil; if it's not there, your oil level might be low. That could be the whole problem.
If they've been running without enough lubrication for any length of time, the bearings probably are worn anyway. It might be a good time just to replace them. They're not expensive.
Dnickels Spitfire Generator fan rubbing/scraping Triumph 3
J Bonnet rubbing Spridgets 12
S TR2/3/3A The chrome beading is rubbing on the hood Triumph 5
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
mrv8q TR2/3/3A TR3 Fuel line rubbing Triumph 8
D TR6 Tire rubbing Triumph 3
D TR6 Brake servo and rear tire rubbing Triumph 4
dcoplan Tires rubbing on frame - suggestions? Spridgets 2
F Spitfire Finally Mobile! Now Grind/Rubbing from Clutch, Gearbox Or? Triumph 5
texbears3 TR4/4A Fan Ext rubbing Steering Rack Triumph 7
S MGB Exhaust rubbing on steering column 77 MGB MG 23
nevets brake rubbing Austin Healey 6
P Rubbing Wheels BN1 Austin Healey 2
DanLewis Bugeye rear brake upgrade - hubs now rubbing Spridgets 3
J rear brake rubbing, need suggestions Triumph 12
I Wax, rubbing compound suggestions Spridgets 10
T Anyone else get rubbing on their VTO rims? Spridgets 31
blackdog Tyre rubbing under hard cornering Austin Healey 12
Jim_Gruber Front Hinged BE Bonnet rubbing on radiator - Spridgets 7
1 Is there a cure for rubbing doors? Spridgets 4
Mio Rubbing noise from right rear wheel Spridgets 14
Brooklands Is Crypty rubbing off? Triumph 13
RobSelina problems with front tires rubbing Spridgets 13
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
I MGB Sticky Rotors/Brakes MG 5
KVH General Tech Rear Brakes and Solid Axle Triumph 2
R Bugeye drum brakes Spridgets 7
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
J Brakes Not Releasing Austin Healey 9
prb51 100-6 Drum Brakes Austin Healey 9
bighealeysource Drum Brakes Assembly Austin Healey 6
A Drum Brakes Again Austin Healey 18
NutmegCT Morris Minor brakes! Other British Cars 9
BritBite XKE BRAKES Jaguar 1
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
algot1901 Brakes for Anglia / Prefect Other British Cars 2
M TR6 76 TR6 Brakes too tight Triumph 10
fundytides Bleeding Lockheed Brakes on 1951 Vanguard Other British Cars 11
K TR2/3/3A Sticking front brakes? Triumph 9
B MGA After-market brakes MG 5
5 TR2/3/3A Seized rear brakes Triumph 9
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
Jeepster Rear Brakes Adjustment Austin Healey 6
C TR2/3/3A bleeding brakes Triumph 11
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
R TR2/3/3A Girling Rear Brakes Triumph 9
A TR6 '74 TR6 no brakes Triumph 14
FlyingCat Spitfire Bleedin' Brakes Triumph 6
R TR2/3/3A Rear Brakes Triumph 9
