Rear Brakes Adjustment
Jeepster
Over the winter I replaced the brake cylinders and shoes on the rear wheels of my BJ8.
When all was back together, I tried to adjust the brakes by tightening the adjuster until the wheel locked, and then backing off slightly. Problem is, I used up 100% of the adjuster to get the brakes to lock ( and they only just managed to lock).
Second problem is the handbrake can't be adjusted to get anywhere near locked enough. It will only just stop the car rolling on a shallow gradient, even with the lever at full.
I’ve adjusted the adjuster to the full extent, and the cable and lever assembly are smooth and giving full movement (cable is reasonable new).
The handbrake did used to operate fine, so it’s not wear in the drums.
Wonder if the new shoes are under size?
roscoe
There was a post within the last month or so on this forum and that turned out to be the problem. The new linings were noteably thinner than originals were. If you can get a real lock of the wheels with the adjuster but the handbbrake is weak you may also have a cable issue.
Guy Marshall
Member
Hi Jeepster - this sounds exactly like the issue I had too. I measured the old drums and they were a little oversize - maybe 1/16 of an inch but enough run out of adjustment. I am sure the new shoes were slightly smaller than the old ones too.
I bought new drums from AH Spares. There weren't too expensive but they took ages to arrive and I had to pay extra tax and duty.
Jeepster
Jeepster
I wonder what the dimensions of the new replacement shoes are compared to new originals? Parts were purchased from AH spares in the UK and I would expect their products to be fit for purpose.
Re the hand brake - I can’t see that the cable is the issue. It’s pretty new and moves as expected. Problem seems to be the full movement of the cable and pivot doesn’t seem to move the pads enough but this may be down to the issue with the shoes.
Maybe I need to source a second set of shoes? Anyone know the original dimension of lining thickness?
It's been awhile, and my memory isn't entirely clear, but IIRC there is an adjustment turnbuckle on the e-brake cable that can be used to take up some slack. Mine was at the limit of adjustment and only the last couple inches of the handle movement would engage the shoes, but I was able to shorten the cable (should be evident how if you have a look). Now my handle/lever starts grabbing after only a couple inches of pull (you want some slack so the shoes don't drag).
Jeepster
Jeepster
I’ve taken out as much slack as possible with the adjuster. Ideally it should be zero slack before the hand brake lever pull starts to move the through lever on the back plate.
problem is now the through lever is at mid movement when the hand brake lever is fully off.
must be the shoes being too thin.
steveg
If you unscrew the clevis from the cable, you can pull the cable out through the stop on the axle. Then you can add some washers between the cable housing and the stop. This will give additional adjustment.
In order to give additional throw, I built these adapter plates for the rear disc kit I used to sell. Possibly they would help with the too-small shoe problem. Just a thought - I never tried them when I had drum brakes.
5 TR2/3/3A Seized rear brakes Triumph 9
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
R TR2/3/3A Girling Rear Brakes Triumph 9
R TR2/3/3A Rear Brakes Triumph 7
M TR6 Rear brakes Triumph 2
Jim_Gruber I think I know why the rear brakes weren't exactly doing their job. Spridgets 9
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Rear brakes - spring plates and drum alignment Triumph 3
oxford Rear Brakes [again!!] Austin Healey 17
oxford rear brakes Austin Healey 14
rjc157 TR6 rear brakes Triumph 11
mgedit TR2/3/3A Steady Springs Rear Brakes 56 TR3 Triumph 0
Jim_Gruber Upgrading rear brakes on a BE Spridgets 6
J TR2/3/3A Installation of rear brake cylinders for 9" brakes on TR 3A. Triumph 3
CJD TR2/3/3A 9 VS 10 Inch Rear Brakes Triumph 15
J TR2/3/3A Rear brakes are not locking up hard enough. Triumph 11
HealeyRick Safely Alert - Midget/Spridget Rear Brakes Spridgets 2
F Spitfire Bleeding Rear Brakes - Ran Into Issues Triumph 7
Boggsy64 MGB Rear brakes caution MG 1
T TR2/3/3A TR 3a. Rear brakes Triumph 2
TR4nut TR2/3/3A Girling 10" Rear Brakes question Triumph 29
mgedit TR2/3/3A Rear Drum Brakes 56 TR3 Triumph 2
S TR2/3/3A rear brakes tr3 Triumph 1
M Bugeye rear brakes Spridgets 3
7 squealing [Humming] sound rear DRUM brakes Other Cars 3
M squeaky rear brakes Spridgets 4
W TR6 broken bleeder on rear brakes tr6 Triumph 6
J TR2/3/3A '56 TR3 Brakes and rear axle advice Triumph 7
TraceZ How I adjusted my new rear brakes Spridgets 7
coj 1960 Healey 3000 front and rear brakes Austin Healey 2
S Spitfire spitfire rear brakes Triumph 5
S installation of rear brakes Triumph 5
S TR2/3/3A tr3 brakes-Rear wheel Triumph 2
B Wedge Help 1976 TR7 Rear Brakes!!! Triumph 11
Moseso TR2/3/3A TR3 Rear Brakes -- A Bold Experiment Triumph 22
P REAR DRUM BRAKES Spridgets 1
M Rear Brakes [from hi-jacked thread] Spridgets 6
M rear disk brakes Spridgets 0
W JagMKII rear brakes dragging Jaguar 13
TimK sticking rear brakes Austin Healey 8
C T-Series Need help to free up rear brakes on TD MG 8
M_Pied_Lourd TR2/3/3A TR3A Rear Brakes Triumph 5
D Rear brakes soaked with grease Austin Healey 2
R Rear Drum Brakes on a BE Spridgets 5
longbridgehealey rear bugeye brakes for dummies Spridgets 11
D Wedge Rear Disc Brakes for TR7 Triumph 16
drooartz Tunebuggery Day 3 -- rear brakes done[ish]! Spridgets 12
drooartz Late rear brakes, Bugeye -- rods adjusted Spridgets 5
bighealeysource Rear brakes on BN1 - HELP !!! Austin Healey 12
