Jim_Gruber
Ok so I started on the top replacement process and drilled out all of the rivets from the top header rail and removed the aluminum trim piece that holds the windshield seal. Is there any way to get the drilled out rivets out of the header rail.
On an MGB Top there is a space that you can shake and all will fall out. I'm guessing on a Spridget it's just one more rattly buzzy noise that I'll never notice with the engine running.
