MiamiSprite
Member
I purchased a powertune remote vacuum servo unit for single line braking systems for my 62 Sprite (948) with disc brakes at front. Brakes work well but want to give my left leg a break.
I was planning on installing it this weekend and figured I'd read the instructions. First thing I noticed is that the two brakes lines supplied ARE DIFFERENT:
Short Line: 3/8"x24UNF Nut with DIN Flare, both ends
Long Line: 10mmx1 Metric Nut with Bubble Flare, both ends
Instrcution show one line from brake M/C to Servo and one from Servo to 3-Way adapter. Unfortunately it does not specify which line to use where.
Assuming the lines supplied are correct, then I'm expecting that when I disconnect the (existing) line from the M/C to the 3-Way adapter that one end will be 3/8" (3-Way?) and the other 10mm (M/C?). Or the lines supplied are wrong. My fear is with crossthreading the Servo (since I will know the threads for the M/C and 3-Way when I remove the existing line).
Anyone have experience with this?
Thanks!
Carlos
Thanks!
Carlos
