pipercollins
Member
Well, I'm in a bit of a bind. I've got an oil drain plug with a badly stripped head. It's holding fine, now, but it's preventing me doing my spring oil change. I'm sure I can get the plug out...eventually. I just don't know if it will be suitable for reuse when I'm done with it.
The problem is, I can't easily replace it. This one is a rare part. I've got a 1976 CA spec 1500 with the remote dipstick on the driver's side of the engine. The oil drain plug goes through the bottom of the dipstick tube, and has a hole through it that allows the oil to come into the tube for reading the level. So a regular replacement drain plug won't work. I could probably fit a regular replacement in the hole, but only if I don't use the diptstick tube. Running without a dipstick isn't a good idea, as anyone reading this forum knows.
So, Question 1: Does anyone have a spare plug such as I need? Moss provides a helpful part number (328-535), but none available. No Vicky Brit, NW, or Spitbits help apparently, either. Rimmer probably won't even have heard of it, since this was a strictly American version.
Question 2: Does anyone have any good tips for extraction and rejuvenation of a brass plug with a rounded head? I suppose I could file the flats to the next smaller size, but I'm sure that sounds easier than it is to get right and still have enough metal to turn it.
I try pretty hard not to over torque it, but here we are. Any help appreciated.
