Question-brake drums
jlaird
Ok the good book says inside diam. of drums is 7" nominal. Mine are at 7" to 7 1/16 inchs and need turned due to rust.
Now the question is how much is the max diam. I can have and still have brakes. ie if 7" in nominal what is the max.
Biff
7 1/8" is max. At 7 1/8"s the brakes will just barely work. How bad is the rust? If it is surface rust, sandpaper them.
jlaird
jlaird
They are going to take a real resurfaceing, I expect new ones are in order
Billm
And DON'T even push the 7 1/8" either, it is not real fun when the pistons pop out of the cylinder during a panic stop!! Been there,done that.
Bill
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
jlaird Todays question - brake drums Spridgets 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
T TR2/3/3A Brake system question - Triumph 4
K TR2/3/3A Another brake bleed question....... Triumph 17
K TR2/3/3A An odd brake question? Triumph 2
K TR2/3/3A Brake pad Question Triumph 3
Lin Brake hard line question Austin Healey 4
J TR6 TR6 Brake Question Triumph 1
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
K Midget Brake Pedal Question Spridgets 2
bighealeysource Question on 100M front brake cylinder Austin Healey 4
D TR2/3/3A clutch/brake pedal question Triumph 4
K TR2/3/3A 3rd brake light question Triumph 3
D BJ8 brake master cylinder question Austin Healey 6
D brake drum question Austin Healey 5
JPSmit Brake Pads - question Restoration & Tools 10
roscoe Brake pad question Austin Healey 3
I TR6 Brake caliper question Triumph 7
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
B Another disc brake question Spridgets 10
PatGalvin TR2/3/3A Drum Brake Question Triumph 3
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
M TR6 Brake master cylinder question. Triumph 2
TomChar TR6 '74 brake failure / oil pressure / ARV wiring question Triumph 19
T TR2/3/3A another brake master cylinder question Triumph 16
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
sd80mac7204 Spitfire 1970 Brake question Triumph 3
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
PatGalvin TR2/3/3A Hard Brake Line Flaring Question Triumph 11
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets question about brake master cylinder Austin Healey 12
nevets Question about brake bleeding Austin Healey 13
J MGB Question on the brake warning light for 78 MGB MG 6
C question on the front brake lines for BJ8 Austin Healey 2
D Question on brake rotors Triumph 3
bugedd Brake bleed question Spridgets 9
bugedd RX7 rear axle and brake question Spridgets 2
H brake/rotor question Austin Healey 28
BillD Bug Eye front drum brake question Spridgets 12
nevets front brake hose question-BN6 Austin Healey 18
D TR2/3/3A TR3 brake rotor question Triumph 4
Mowgli81 General Brake Question & repair manual Austin Healey 25
T TR2/3/3A tr3 brake/clutch reservior question Triumph 1
A Wedge 1980 TR7 Brake master Question Triumph 5
T Rear brake clyinder orientation question Triumph 4
