Question about brake bleeding
nevets
After replacing front wheel cylinders and flex hoses, will it be necessary to bleed the master cylinder?
Thanks!
Keoke
Naw that is not generally requierd
nevets
nevets
Thanks Keoke, now one more wrinkle...I started to bleed the brakes using an EZ-Bleed pressurized bleeder, but when I got to the 3rd wheel (right front), I noticed that I unwittingly allowed the bleeder reservoir to go dry. Given these circumstances, do you think I will need to bleed the MC? What about the clutch slave cylinder?
Keoke
??????????????-------Keoke
Keoke
I'll assume that your reply means - maybe
Yep.
However the clutch is aseparate system and should not have been affected.
steveg
When I recently installed my Toyota calipers with new hoses, found that gravity bleeding worked well. I'd pump the pedal a few times, then undo the bleeder screw slightly, letting the fluid flow until the bubbles quit. First bleed the driver's side, then the passenger side. The fluid flows from the reservoir through the master cylinder into the lines and through the hoses and calipers.
nevets
nevets
Steve G, When you did gravity bleeding, did you have a tube connected to the bleeder screw to a jar of brake fluid?
steveg
Yes. Open the bleeder screw until the fluid starts to flow, holding the screw against its seat to keep extra air from entering from the outside. Top up the reservoir as necessary. If your pedal is still spongy, repeat.
HealeyRick
If you do gravity bleeding, how do you get to spend quality time with your spouse?
steveg
You mean you've never had your spouse as a helper to push the brake pedal down while pressure bleeding? "Push down." "Hold it" "Let it up" "Push down again" "Hold it" "No, that's the clutch pedal." Probably responsible for more divorces than any other auto repair.
OK, I get it. In my crowd we refer to the spouse as the "Dreaded Assistant". We will do almost anything to avoid invoking the Dreaded Assistant.
Monark192 Brake Bleeding Question MG 22
T TR2/3/3A TR3A Disk Brake Question Triumph 10
T TR2/3/3A Brake system question - Triumph 4
K TR2/3/3A Another brake bleed question....... Triumph 17
K TR2/3/3A An odd brake question? Triumph 2
K TR2/3/3A Brake pad Question Triumph 3
Lin Brake hard line question Austin Healey 4
J TR6 TR6 Brake Question Triumph 1
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
K Midget Brake Pedal Question Spridgets 2
bighealeysource Question on 100M front brake cylinder Austin Healey 4
D TR2/3/3A clutch/brake pedal question Triumph 4
K TR2/3/3A 3rd brake light question Triumph 3
D BJ8 brake master cylinder question Austin Healey 6
D brake drum question Austin Healey 5
JPSmit Brake Pads - question Restoration & Tools 10
roscoe Brake pad question Austin Healey 3
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
I TR6 Brake caliper question Triumph 7
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
B Another disc brake question Spridgets 10
PatGalvin TR2/3/3A Drum Brake Question Triumph 3
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
M TR6 Brake master cylinder question. Triumph 2
TomChar TR6 '74 brake failure / oil pressure / ARV wiring question Triumph 19
T TR2/3/3A another brake master cylinder question Triumph 16
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
sd80mac7204 Spitfire 1970 Brake question Triumph 3
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
PatGalvin TR2/3/3A Hard Brake Line Flaring Question Triumph 11
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets question about brake master cylinder Austin Healey 12
J MGB Question on the brake warning light for 78 MGB MG 6
C question on the front brake lines for BJ8 Austin Healey 2
D Question on brake rotors Triumph 3
bugedd Brake bleed question Spridgets 9
bugedd RX7 rear axle and brake question Spridgets 2
H brake/rotor question Austin Healey 28
BillD Bug Eye front drum brake question Spridgets 12
nevets front brake hose question-BN6 Austin Healey 18
D TR2/3/3A TR3 brake rotor question Triumph 4
Mowgli81 General Brake Question & repair manual Austin Healey 25
T TR2/3/3A tr3 brake/clutch reservior question Triumph 1
A Wedge 1980 TR7 Brake master Question Triumph 5
T Rear brake clyinder orientation question Triumph 4
J Question on rear brake mounting plates Spridgets 5
