Brake Bleeding Question
Monark192
I can get a nice stream of fluid from either front brake but the rears do nothing when the bleed valve is backed off and the pedal pushed. Can there be an airlock in the system somewhere?
jlaird
For sure, bleed the longest line first, passanger rear I expect, and just do it again and again and again.
tony barnhill
Great Pumpkin - R.I.P
[ QUOTE ]
[/ QUOTE ]
Yes, simon, you could have lots of air in there - do as Jack suggested: start with the wheel farthest from the masdter cylinder & get it to flow first.
Monark192
Monark192
I have a feeling that the "again and again and again" could wear out my wife's pedal pushing patience. Sounds like time to visit the neighbor, extra beer in hand.....
jlaird
Oh yea, sometimes 20 times or more.
tony barnhill
Get an empty beer can (you can handle that part)...fill it halfway full of brake fluid..stich a hose down in it & attach the other end to the opened bleeder...fill the master cylinder with fluid & get inside & pump...no air can get back into the system...as fluid leaves the cylinder add more...when the can overflows, call the wife.
vping
Bronze
[ QUOTE ]
[/ QUOTE ]
I did this with my son. It took awhile and there was some whining but then victory!
philman
did you bleed the master cylinder before going back to the wheel cylinder?
philman
i used a mityvac unit. it's the only time i've got it to work. i rebuilt the master cylinder for my tr7 (the same as a later mgb master cylinder). I could bleed the front brakes at the wheel, but not the rear. I tried for at least half an hour pumping the pedal with a bleeder hose attached at the rear wheel cylinder with no effect. I took the brake line for the rear brakes off at the proportioning valve and bled from the master cylinder, then i reconnected the brake line and was able to bleed from the rear cylinders. there are other ways to bleed the master cylinder, all should work.
Guinn
I'm not about to go out in the cccold to check, but it seems to me that the driver's side (left side) rear wheel is the farthest from the master cylinder - if you trace the tubing. I believe the single flex tube diverts just above the rear axle, on the right side.
See Moss pg 57 or VB pg 146 which show diagrams.
Do bleed as suggested: farthest wheel first.
Guinn
Guinn
PAUL161
I know this might sound goofy to some, but I fill my systems the same as I fill Aircraft brake systems. From the bleed valve back. Usually takes all the air with it. Works great on clutch systems too. You just have to watch that the MC reservoir doesn't overflow. Oh, and no pestering the wife to pump the pedal. /ubbthreads/images/graemlins/jester.gif PJ
LLAngus
Check the Tool forum to see how to make an inexpensive pressure bleeder. It works.
/ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/hammer.gif
jlaird
Paul, think I like that idea. Gota consider it some.
I've got my garden sprayer, and am slowly working on making one of those.
maynard
Check the brake lines. Often on Bs, if the car is towed backwards (which may have happened before you got the car) the tow hooks crimp the lines.
Yes, sometimes flatbed towing will pinch the metal lines going across the rear axle.
Monark192
Monark192
Metal lines look good and the flex hose is ok. I was starting on the drives side rear as it seemed furthest from the master as the brake fluid flows.
nevets Question about brake bleeding Austin Healey 13
Frameman 1949 Brake Bleeding Austin Healey 0
KVH General Tech TR4A Brake Bleeding Triumph 5
Govtslug TR6 Brake Bleeding Triumph 58
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
N Need brake bleeding advice Spridgets 6
J Spitfire Spitfire Rear Brake Bleeding Triumph 9
R Still Another Healey Brake Bleeding Saga [unfinished] Austin Healey 9
nevets brake bleeding Austin Healey 13
vickxxx T-Series Brake bleeding MG TD MG 10
R General Tech One Person Brake Bleeding with a Mityvac Triumph 12
Simmo Series 3 E Type Brake Bleeding Jaguar 2
jlaird Brake and Clutch bleeding Spridgets 7
N Need Brake Bleeding Help Spridgets 25
J TR2/3/3A Brake Bleeding problem on a TR3A Triumph 19
T TR2/3/3A One Person TR3 Brake Bleeding Option? Triumph 11
Bremer TR2/3/3A TR3A: Strange brake bleeding behaviour Triumph 4
D TR6 76 TR6 New Brake Bleeding Triumph 4
KVH Bleeding the Brake Master Cylinder Triumph 8
B Brake bleeding issues....Help please... Triumph 16
D Dual Circuit Brake Bleeding Triumph 7
W Off to the local shop... brake line bleeding Spridgets 2
W Problems!! Brake line bleeding and leaks Spridgets 5
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
Basil Brake Bleeding Wish me luck Jaguar 10
O Jaguar ABS Brake Bleeding Jaguar 1
Basil Bleeding an XKE Brake System Jaguar 6
WALTER Later model brake bleeding Spridgets 17
Nelson Brake bleeding Spridgets 22
glemon MGB MGB Brake Bleeding MG 14
tahoe healey brake bleeding Austin Healey 7
tahoe healey brake bleeding sequence Austin Healey 2
Michael Oritt Bleeding dual master cylinder brake system Austin Healey 6
D Brake Bleeding Triumph 2
MadRiver Brake bleeding problems Triumph 10
MadRiver Brake bleeding advice Triumph 12
A Brake bleeding [say that three times fast] MG 6
S Brake Bleeding Problem!? Triumph 6
tr6web TR6 Brake MC and bleeding TR6 Triumph 7
George Zeck Brake Bleeding ?? Spridgets 15
L Brake Bleeding MG 2
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
