TR6 TR6 Brake Question
Jerryny
Good Morning all,
I have a question concerning my 1973 TR6 brakes. Should I be able to lock the rear tires when applying the brake w/o the car running(not using power booster). Currently I can still spin the rear tire with the brake applied. Any help is appreciated.
Jerry
1973 White TR6
Yes, applying the brakes with or without power assist should prevent you from turning the rear wheels by hand.
Adjust the hand brake cable and the brake shoes
The wheels should lock when the hand brake lifts 3 ...or 4 clicks at most.
mlarnoldTR6 TR6 TR6 Brake Question. Triumph 6
charlie74 TR6 handbrake adjustment tool Restoration & Tools 0
EWD TR6 74 TR6 - Handbrake handle reinstall Triumph 2
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J TR6 TR6 Brake Pad Shims Triumph 1
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
PeterK General TR Need a handbrake button and rod TR4a-TR6 Triumph 5
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
A TR6 '73 tr6 passenger front brake dragging Triumph 2
C TR6 TR6 with dot 5 brake fluid Triumph 8
sundown TR6 1973 TR6 brake booster hose Triumph 7
smaceng TR6 TR6 brake pressure balance valve Triumph 2
D TR6 76 TR6 New Brake Bleeding Triumph 4
D TR6 76 TR6 Rear Brake Installation Triumph 17
D TR6 76 TR6 Brake Servo Triumph 2
D TR6 76 TR6 Rear Right Brake Line Triumph 8
bobh TR6 TR6 Brake Upgrade Triumph 19
W TR6 TR6 brake pedal drip Triumph 12
D TR6 TR6 Puddle of Brake Fluid on the floor Triumph 8
M TR6 Tr6 Brake Pull Triumph 6
BobbyD TR6 TR6 and other TRs - Brake Light Switch Alternative Triumph 7
sundown TR6 TR6 e-brake Triumph 2
M TR6 Where does this TR6 brake line go?[pic] Triumph 3
hondo402000 TR6 71 TR6 Brake warning light and oil pressure light Triumph 6
T TR6 TR250/TR6 - Improving hand brake mech advantage Triumph 11
J TR6 70 TR6 Brake Booster Triumph 4
hondo402000 TR6 TR6 power brake bleeder Triumph 10
Phil73 TR6 TR6 brake issues Triumph 13
PatGalvin TR6 Need TR6 Brake Caliper Brackets Triumph 15
Z TR6 TR6 Brake Issue Triumph 8
wangdango TR6 TR6 brake servo rebuild kit? Triumph 2
I TR6 TR6 brake squeal Triumph 8
bigbadbluetr6 TR6 TR6 Brake Problems Triumph 6
mabbott TR6 Brake fluid in 73 TR6? Triumph 6
T TR6 Anyone have a spare TR4/TR6 brake master lid? Triumph 4
I TR6 TR6 - how many brake caliper shims? Triumph 26
Brosky TR6 Really BIG Brake Kit for TR6 Triumph 15
I TR6 A few dumb TR6 brake questions Triumph 9
TR6oldtimer TR6 TR6 Brake caliper part. Triumph 6
TR6oldtimer TR6 TR6 brake calipers Triumph 6
TR6oldtimer TR6 TR6 Hand Brake Install Triumph 2
I TR6 Rear brake drum temperature TR6 Triumph 13
hondo402000 TR6 Front Brake issues TR6 Triumph 2
hondo402000 TR6 figured out my low brake peddle problem TR6 Triumph 1
hondo402000 TR6 TR6 rear brake rebuild Triumph 10
I TR6 69 TR6 brake booster Triumph 2
T TR6 Any tips for replacing TR6 rear brake lines Triumph 10
