Play in timing chain
WALTER
How much is too much on a 1275 engine?
Thanks,
Walter
jcatnite
According to my Hanes, "Lay a straight edge along the slack leg of the chain. Run and measure the extent of chain slack from the straight edge. If it is more than 0.4" (10mm) the chain should be renewed.
I've always used 1/2" so I guess this is pretty close. The 1275 doesn't have a tensioner does it?
Hope this helps,
JC
WALTER
WALTER
No tensioner. Yes, this helps a lot.
Thanks
Walter
M Layshaft End Play Austin Healey 7
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
M T-Series MG TD 1st/2nd sliding hub end play MG 1
M T-Series TD/TF Steering Free Play Question MG 6
AUSMHLY 1st Motion Shaft Play Austin Healey 3
B MGB Mgb crankshaft end play shims MG 2
Walter74 Steering Box End Play Austin Healey 2
Jayplum TR2/3/3A Steering Box end play Triumph 6
RickPA Play in steering Austin Healey 12
doc50 Adjusting play on steering box? Other British Cars 5
K TR2/3/3A Checking steering box End Play? Triumph 5
D TR4/4A How much play acceptable for input shaft bushing? Triumph 2
matmire 23d4 distributor clockwise play... normal? Spridgets 4
4tecdog Play in first motion shaft on BJ8 Austin Healey 3
J Clutch fork free play on BJ8 How Much? Austin Healey 13
S TR2/3/3A Distributor drive shaft play Triumph 4
RAC68 Calculating Front Hub End-Play Austin Healey 32
TRMark TR4/4A Play in steering pinion & rack mount mod Triumph 3
I TR6 Steering wheel play Triumph 11
Tinkerman TR2/3/3A 1960 TR 3A excessive 3" to 4" steering wheel play. Triumph 2
D T-Series Let's play "What kind of transmission does this go in?" MG 1
Tinkerman TR2/3/3A 1960 TR3 A Steering wheel play or Lash Triumph 2
A LOTS of wheel play Triumph 12
W 100-4 distributor end play Austin Healey 0
RJS Differential Play Returns Triumph 8
TRclassic3 TR2/3/3A diff free play tr3 Triumph 7
glemon Triumphs at Play Triumph 10
T Anybody Want to Play "Identify the Crud"? Triumph 2
lbc_newbie Let's play.."What's my car worth" Spridgets 13
T TR4/4A TR4a steering shaft play Triumph 21
CinneaghTR Let's Play "Name That Part!"-Sidescreen TR Triumph 10
A TR2/3/3A TR3 Trunnion - vertical link play Triumph 10
T Question on play on steering column Triumph 5
L How much play in your steering? Austin Healey 13
Morris No wife, no kids.... time to play Spridgets 11
6 crank end play Triumph 9
KVH TR4/4A TR4A Allowable Half Axle Play Triumph 0
D Steering play Austin Healey 14
Darwin Adjusting steering play? Triumph 7
T BE Phantom Rear Axle End Play Spridgets 0
pjsmetana New Lugnuts? Drive shaft Play? Triumph 7
T Play in gearbox input shaft Austin Healey 6
D first gear sliding hub play Austin Healey 10
6 End Play in BJ8 Idler Austin Healey 2
chicken Play in the rear axle Austin Healey 2
Tabcon Crankshaft End Play Racing 8
C Distributor shaft vertical play? Triumph 4
TR4nut Question on rebuilt generator - armature play? Triumph 10
bigjones Play in Front Wheels Triumph 31
regularman Ok, odometer play time. Spridgets 48
