I know that I have seen this but I cannot find it in the archives. (that doesn't meant it isn't there, I just can't find it)
What is the acceptable crank end play and where is the best place to check it? I might be dropping the oil pan to try to find the missing split pin from the rocker shaft. If so, would that be the best place to check it?
Thanks for any help, Pete
