RAC68
Calculating Front Hub End-Play
OK, maybe my memory is getting a little shadowy and the things I just put down seem to disappear, later to turn up exactly where I remember putting them down, but I usually remember what I have done to my Healey…no matter how far in the past.
Finding excessive end play in the left front, today I decided to determine what thickness the shims in place are and calculate the extent of the endplay and shims needed. I wanted to do this in anticipating of receiving new outer bearings and to prepare for their installation. Well, having done this task around 3 decades ago, I could not remember how to measure the end play.
Raising the car and removing the wheel, dust cap, caliper, and cotter pin, I torqued the castle bolt to 60 PSI and pushed the hub back as far as it would go. I then inserted the tail extension of the micrometer to the tab washer and rested the rear foot of the micrometer onto the outside lip of the hub. Registering the micrometer at 0 when fully pressed back, I then pulled the hub forward and took the reading.
Is this procedure correct and is there an easier way to determine end play for a shim calculation?
I appreciate that 0 end play is the acceptable nomenclature, however, is there an acceptable clearance (i.e. +/- 0.002-0.004)?
Thanks all,
Ray (64BJ8P1)
P.S. I was asked recently, “Why do you own a Healey?” “Mental health” was my reply. “It always gives me something to think about.”
Thanks all,
Ray (64BJ8P1)
