Paint question for Jack [or anyone else wise]
JPSmit
Jack, not too long ago, someone was asking about painting his engine (he was looking for high heat engine paint in green as I recall)
I seem to remember you saying you didn't prime your engine before you painted it-
Any reason?
TIA
JP
jlaird
No reason at all, I just never have nor have seen it done.
Now that does not say it is wrong to do so. I just never have and I have painted quite a few. Have never had the paint come loose either, shrug.
What you other guys say, is a good question.
Shealey
If you prime it, use a acid based or self etching primer. Watch the mil thickness if you prime. There is alot of heat and expansion and contraction working against the adhesion. Engine paint works fine without priming. It's soft and durable as well as heat resistant. If your going to use a custom color you may want to prime first to increase adhesion. You may want to also use a flex additive to help with the adhesion, expansion and contraction.
jlaird
Ahhhh, makes sense to me. Always wondered why I did it that way.
John Loftus
The Hirsche engine enamel instructions said that no primer is needed for the block and head (because they are porous). Just make sure it is clean of grease and oils. For all the smooth metal parts such as valve cover, side access panels, oil pan, etc. use a primer.
Here's the page with the instructions:
https://hirschauto.com/engine.htm
JPSmit
JPSmit
That's pretty much what I've been doing - thanks for the confirmation
Crankshaft TR2/3/3A Fresh paint prep question Triumph 6
nevets Question about original Healey paint quality Austin Healey 20
B Question for the paint pros Triumph 8
H engine paint question Austin Healey 19
I TR6 TR6 paint question Triumph 8
scott_74 Sill Paint Question Spridgets 3
A question about media blasting and engine paint. Austin Healey 14
bgbassplyr PAINT CODE QUESTION.... Triumph 1
O bonnet plinths/raised hinges and a paint question Triumph 12
W Question on polishing up old paint Restoration & Tools 3
G Historical Paint Question Triumph 24
R Paint question...Same Body Color or Change Color? Triumph 17
T Radiator paint question Triumph 4
JPSmit concours paint question - you purists Spridgets 6
S a paint question Restoration & Tools 4
zimmy paint question Spridgets 9
JPSmit Gas tank paint question Spridgets 4
JPSmit Paint Question - seat runners Spridgets 12
JPSmit Paint Code Question - OEW Austin Healey 5
JPSmit New Mini paint question British Motor Corp 4
JPSmit Tonight question #1 - Paint Colour Restoration & Tools 8
6 Paint Detailing Question: Fiberglass Austin Healey 14
Daimlerdb18 MGA Holy Blisters! MGA Paint Question MG 22
JPSmit trim paint question Restoration & Tools 5
regularman Question for paint experienced people [whew] Spridgets 17
WALTER paint compatability question Spridgets 5
B Question on paint typs for engine parts? Restoration & Tools 16
T Paint question Triumph 2
JPSmit Paint Colour Question Spridgets 3
Bruce_B Paint Question - bonnet of BE Spridgets 2
Morris Weird paint question Spridgets 14
regularman I have a paint question Spridgets 26
JPSmit Last Question [tonight] To Paint or not to Paint Spridgets 2
budk1953 Paint Question MG 2
D TR2/3/3A 1960 TR3A Paint Question Triumph 24
D Paint question Spridgets 10
jlaird Question-dash paint Spridgets 4
jlaird Question-paint Spridgets 19
MadRiver Another paint question -- exhaust manifold Triumph 5
R Another Paint Question Austin Healey 1
C Paint Question... Spridgets 1
Simon TR4a Paint question. Triumph 6
J Paint prep question Restoration & Tools 2
Basil A question of paint Jaguar 1
I Paint question XK150 Jaguar 2
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
