paint compatability question
WALTER
I'm painting the body of my Sprite with yellow Centari. My friend gave me a quart of silver Delstar. Can I paint stripes with the Delstar over the Centari?
Thanks,
Walter
bugimike
Your best bet is to paint a small sample piece and try it on that! That is the only foolproof way without having the labels to read as to what solvent base each type requires!
Bayless
Both are acrylic enamels so probably safe. Do test first though. Also, if you are not catalyzing the Centari, be sure to wait at least a month or two before overpainting, even if the test looks good.
WALTER
WALTER
Thanks guys. I am catalyzing. But I'm curious. Why wouldn't you catalyze?
Walter
Bayless
Probably the #1 reason is the isocyanates in the catalyst. The stuff is not real healthy. And it can't be filtered since the molecules are smaller than air molecules. Read the MSDS.
John Loftus
Best to have a forced air system (instead of a filtered mask)when shooting catalysed paints. I have a Hobby air and it works great. Keep as much skin covered as possible too. If I was painting something large (especially if not in a well ventilated paint booth), I would use sealed goggles over the eyes since the chemicals can be absorbed through the eye membrane. Yes, nasty stuff but the paint is much more durable and chemically resistant with it.
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
EWD TR6 TR6 top dash trim paint Triumph 2
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
GeorgeC OK to paint battery? Spridgets 9
J Opalescent Silver Blue paint code Jaguar 0
Vargus TR2/3/3A what primer / paint ? Triumph 9
T TR4/4A Fenders off the car for paint? Triumph 8
B TR4/4A Wheel Paint Triumph 17
B TR6 what paint to use? Triumph 7
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
D TR6 Valve cover paint Triumph 5
TomMull Paint over galvanized parts? Restoration & Tools 8
Sopwith_Camel MGB-GT lick of paint 1 2 3 MG 2
Rut MGB Pale Primrose touch up paint MG 4
J Paint code Spridgets 0
J 1960 Bugeye Paint Codes Austin Healey 1
J Paint code Austin Healey 4
M Old English White Paint Code for early BE Spridgets 1
J Flaking Paint Inside Differential Austin Healey 6
C Under boot and under bonnet paint? Austin Healey 7
T TR2/3/3A Chassis paint color Triumph 10
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
vette MGB Paint Code MG 8
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
B Engine paint Austin Healey 17
D Lotus Elan S4..Bodywork evaluation..Strip & Paint? Lotus 10
P TR2/3/3A Chassis paint questions Triumph 8
B Carnauba wax Vs. new ceramic paint sealants Austin Healey 35
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
