Radiator paint question
tdskip
Anything special here - I know Eastwood sells paint specificailly for use on radiators but I'm not sure if that is any different or better than say this;
martx-5
Radiators don't get that hot...hopefully less then about 200 deg. Most rattle can paints should handle that, I don't think you even need any high temp paint. Eastwood sells a lot of good products, but at fairly high prices. I think this is one of those times that any decent paint will do. Just look on the label to how high of a temp it will take.
Geo Hahn
This issue may not be just temp but also the thickness or heat conductivity of the paint.
I believe a heavy coat of paint on a radiator can be detrimental to cooling.
There are paints that are almost as thin as ink (like the black from a Magic Marker). Don't know if that is a characteristic of the Eastwood paint but with a phone call you could probably find out.
TR rads are challenged in the best of times so anything that reduces their performance is to be avoided.
DaveatMoon
I have some of the Eastwood radiator paint but haven't used it yet. It's selling point <span style="font-style: italic">is</span> it's thinness and temperature conductivity. I believe that there are other brands lurking on the shelves of Advance/Pep Boys/et al that will work as well, however.
You can easily and probably will seriously effect the cooling capacity of a radiator painting it with normal spray paints. There's a thread on the AACA forum right now by a guy who painted his 1930s Chrysler rad with Imron (becaue it looked nice), and now he can't drive it for more than 15 minutes.
The Krylon can pictured is for a steam heat radiator. It's main selling point is good thermal adhesion and elasticity. You'd have to ask them what it's thermal conductivity is like.
PeterK
I used Eastwood's radiator paint. It's thinner than "regular paint" and provides a nice coating. I avoided overspraying the fins nonetheless. Just enough to coat. Never use engine enamel as it has very high solids and too thick for this application.
M Radiator Paint Austin Healey 20
NutmegCT paint a brass radiator? Restoration & Tools 7
RJS Radiator Paint Triumph 5
J SafelyRemoving Paint Overspray from radiator fins? Austin Healey 8
Nelson Radiator paint Spridgets 10
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
J BJ8 Radiator Fan Austin Healey 12
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
R TR6 Radiator protection shield differences Triumph 0
K For Sale TR3 Radiator Guard Triumph Classifieds 0
S For Sale Mg tf new radiator shell-slats-false nose-emblem MG Classifieds 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
edkap2002 TR6 lower radiator hose fitting Triumph 2
nevets Radiator Overflow Tank Austin Healey 23
K TR2/3/3A Radiator coolant level? Triumph 5
K TR2/3/3A Radiator drain tap? Triumph 4
D TR2/3/3A radiator overflow restrictor Triumph 9
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
G 100/6 Radiator cross member Austin Healey 6
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
S TR2/3/3A and the radiator was leaking. Triumph 7
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
B Radiator Baffle Installation Austin Healey 4
S Painting a BJ8 Radiator - any advice? Austin Healey 17
S Bugeye Radiator Tank Plug Size? Spridgets 24
FlyingCat Spitfire Electric Radiator Fan Triumph 10
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
FlyingCat Spitfire Radiator and fan Triumph 5
aero3113 Radiator overflow catch tank Austin Healey 15
Sarastro TR4/4A What radiator do I have? Triumph 4
Patrick67BJ8 Radiator & Engine Flush Austin Healey 10
