Have one I never expected.
Have had an oil leak for quite a while that I could not determine the source of the leak.
Doing some exhaust work and other work on electrics I happened to notice that I was noticing a trail of oil leaking from around the adaptor into the engine block from the oil cooler (Moss #460-820). After disconnecting the oil line and pulling the adaptor I noticed a portion of the washer (Moss #324-800) was broken out. No big question as to what the problem probably is. Here's the problem. The washer is one of those collapsible type that costs a total of 55 cents! I'd have to order 19 of these plus $5.75 shipping in order to meet the minimum order Moss will accept. The question: Is there a standard washer I could use that would fit the bill? The diameter over the threads measures out to be .820 which, I guess, is a British thread. Any ideas? (it is a copper washer)
