Oil Cooler Leak
angelfj1
Found a small (new) puddle of oil under the 250 this morning. I traced it to the oil cooler. At first I thought that the leak was at one of the two threaded connections. No, such luck. This thing is all aluminum and is part of the set up with the spin-on filter adapter, etc that I bought from Moss, part number 235-995, 16 row, dimensions, 11"x5"x2". I notice dozens oil coolers available domestically for less than half of the Moss replacement price of $160.
How critical is the size and how can I be sure that the threads are identical?
3798j
Bronze
Frank, On my GT6, I run a Mocal 10 row with a Mocal thermostat (180deg.). I think it works great on the 2.0 6 cylinder. That threading business is another story. My guess, if you purchased from Moss, you would want the BSP threading. Take a look at this from Mocal: https://64.202.180.37/files/tchart.pdf. It should allow you to determine what you've got.
angelfj1
angelfj1
Peter: OK, so the cooler requires a rigid mounting. I had 4 - 1/4-28 bolts/nuts through the bottom flange and the radiator bottom shield. Do you believe this could have caused the leak. The mounting kit appears to provide clamping force between the top and bottom plate. Is that correct? BTW, it appears that I actually got this unit from TRF. I am hoping they will send me a replacement.
Thanks for your input.
PeterK
Yes, the 1/4-28x? bottom only mounting is a problem. Use top and bottom reinforcing plates and long bolts that clamp the cooler tight. Might also want to tie-wrap the hoses to prevent torquing the fittings.
hth
-PK
TR6BILL
I agree with Peter, aluminum oil coolers <span style="font-weight: bold">will</span> crack and cause you to loose your oil. A friend's cooler split, luckily while he parked in his driveway, and dumped his whole oil supply. I used the Earl's clamp on top and bottom and scored four long pieces of stainless 1/4" all-thread and a bunch of stainless nuts, washers and lock nuts to brace the whole thing to the skid plate. Used multiples of each to lock the all-thread to the plate, to the brackets and to itself. Meaning, didn't so much over clamp the cooler as made a very rigid cage for it to rest in. Understand?
angelfj1
angelfj1
Bill, yes I understand the issue now - OK
angelfj1 Oil Cooler Leak Triumph 9
Celtic 77 MGB 77 MG B oil cooler MG 5
B Oil cooler Austin Healey 21
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
MikeAH100M Interesting Oil Cooler Austin Healey 6
H oil cooler and overheating Austin Healey 12
JPSmit engine oil cooler question Spridgets 11
RAC68 Routing Oil Cooler Lines Austin Healey 16
Scotsman TR2/3/3A How to Mounting Oil Cooler on TR3 Triumph 3
DanLewis Oil cooler hose fittings - 5/8 UNF versus 3/8 NPT Spridgets 2
DanLewis Solved the oil cooler mounting problem in my Bugeye! Spridgets 8
DanLewis Other ways to mount an oil cooler on a Bugeye Spridgets 3
DanLewis Oil cooler hose adapters? Spridgets 12
Branson oil cooler mount Spridgets 20
6 Oil Cooler Spridgets 3
R oil cooler need for 1500midget with 9:1 comp ratio Spridgets 3
H oil cooler overall cooling component Austin Healey 7
P broken oil cooler fitting MG 1
D oil cooler Spridgets 12
hondo402000 getting rid of my oil cooler, hoses, thermostat Triumph 2
V How much extra engine oil with oil cooler??? Spridgets 5
8 TR4/4A TR4A After market Oil Cooler Triumph 5
DerekJ Is my oil cooler a waste of time? Austin Healey 1
S Oil cooler and spin on filter adapter Triumph 10
tri_carb_healey oil cooler question. Austin Healey 5
hymodyne GT6 spin-on oil filter adapter w/ oil cooler GT6 Triumph 12
B TR6 TR6 Oil Cooler hoses Triumph 1
rikiwho123 oil cooler kit Triumph 0
D Help! Blew an oil cooler hose. MG 17
HealeyPassion AH oil cooler ducts Austin Healey 16
A Oil Cooler Washer MG 4
M_Pied_Lourd TR2/3/3A TR3A Oil Cooler Opinions Triumph 5
Sebring222 MGB MGB Oil Cooler Thermostat MG 4
Tabcon Oil Cooler Install Help Racing 0
jaegzie Do/Should I use an oil cooler. Spridgets 11
losmorob Looking for an oil cooler kit Spridgets 7
chrpark oil cooler install and fitting pictures Spridgets 1
0 1500 oil cooler Spridgets 3
B GT6 GT6 Oil Cooler Kit for TR6 Application Triumph 3
tony barnhill '63 Midget Oil Cooler Hoses Spridgets 5
J Oil flow direction and oil cooler Spridgets 14
Jim_Gruber Oil Cooler Hoses / Rerouting / Hole Saw Spridgets 5
Baz Oil Cooler lines... Spridgets 0
G Oil Cooler question Triumph 14
beez Oil Cooler with Thermostat Installation Question Triumph 8
B 1500 Oil Cooler Spridgets 7
Jim_Gruber Oil Cooler Hoses - Routing and supporting Spridgets 10
D Oil cooler MG 6
WALTER Benefit of an oil cooler Austin Healey 7
Jim_Gruber New Oil Cooler and Engine Temps / Pressures - Resu Spridgets 2
