oil cooler install and fitting pictures
chrpark
Anyone have photos of how the oil cooler mounts in a Sprite Mk II/Midget Mk I or similar model? Also looking for the plumbing connections to the motor. Thanks in advance
Billm
If you have a spin-on oil filter already adapted then the easiest way is to use a "sandwich plate" adapter between the oil filter and the adapter (temperature controlles one WON'T fit but regular one will).
If you still have the canister filter then the easiest way is to cut the pipe from the engine to the oil filter and run hoses from those cut ends (with several hose clamps on each end).
As for the oil cooler itself- just bolt it in front of the radiator and call it good!
Bill
(now let the "shark-feed" begin!!)
Tabcon Oil Cooler Install Help Racing 0
F TR6 Need help w/TR6 oil cooler install... Triumph 16
Celtic 77 MGB 77 MG B oil cooler MG 5
B Oil cooler Austin Healey 21
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
MikeAH100M Interesting Oil Cooler Austin Healey 6
H oil cooler and overheating Austin Healey 12
JPSmit engine oil cooler question Spridgets 11
RAC68 Routing Oil Cooler Lines Austin Healey 16
Scotsman TR2/3/3A How to Mounting Oil Cooler on TR3 Triumph 3
DanLewis Oil cooler hose fittings - 5/8 UNF versus 3/8 NPT Spridgets 2
DanLewis Solved the oil cooler mounting problem in my Bugeye! Spridgets 8
DanLewis Other ways to mount an oil cooler on a Bugeye Spridgets 3
DanLewis Oil cooler hose adapters? Spridgets 12
Branson oil cooler mount Spridgets 20
6 Oil Cooler Spridgets 3
R oil cooler need for 1500midget with 9:1 comp ratio Spridgets 3
H oil cooler overall cooling component Austin Healey 7
P broken oil cooler fitting MG 1
D oil cooler Spridgets 12
hondo402000 getting rid of my oil cooler, hoses, thermostat Triumph 2
V How much extra engine oil with oil cooler??? Spridgets 5
8 TR4/4A TR4A After market Oil Cooler Triumph 5
DerekJ Is my oil cooler a waste of time? Austin Healey 1
S Oil cooler and spin on filter adapter Triumph 10
tri_carb_healey oil cooler question. Austin Healey 5
hymodyne GT6 spin-on oil filter adapter w/ oil cooler GT6 Triumph 12
B TR6 TR6 Oil Cooler hoses Triumph 1
rikiwho123 oil cooler kit Triumph 0
D Help! Blew an oil cooler hose. MG 17
HealeyPassion AH oil cooler ducts Austin Healey 16
A Oil Cooler Washer MG 4
M_Pied_Lourd TR2/3/3A TR3A Oil Cooler Opinions Triumph 5
Sebring222 MGB MGB Oil Cooler Thermostat MG 4
angelfj1 Oil Cooler Leak Triumph 8
jaegzie Do/Should I use an oil cooler. Spridgets 11
losmorob Looking for an oil cooler kit Spridgets 7
0 1500 oil cooler Spridgets 3
B GT6 GT6 Oil Cooler Kit for TR6 Application Triumph 3
tony barnhill '63 Midget Oil Cooler Hoses Spridgets 5
angelfj1 Oil Cooler Leak Triumph 9
J Oil flow direction and oil cooler Spridgets 14
Jim_Gruber Oil Cooler Hoses / Rerouting / Hole Saw Spridgets 5
Baz Oil Cooler lines... Spridgets 0
G Oil Cooler question Triumph 14
beez Oil Cooler with Thermostat Installation Question Triumph 8
B 1500 Oil Cooler Spridgets 7
Jim_Gruber Oil Cooler Hoses - Routing and supporting Spridgets 10
D Oil cooler MG 6
WALTER Benefit of an oil cooler Austin Healey 7
