AH oil cooler ducts
That's nice, I noticed the rolled edges when looking at your paper on wet-sanding and polishing the paint, good job!
I took a somewhat less technical approach, using a 3" conduit K/O punch to get radiused ends, simply cutting out the material left in between.
I fabicated a stainless steel duct to direct air into the cooler matrix, attaching it to the shroud with aircraft "cherry" rivets sandwiching a #10 stainless steel screen between the two (and I have a particular fondness for Pinin Farina's similar use of exposed rivets on the Ferrari 375 Mille Miglia; see: https://www.rfdm.com/gallery/album116 ).
Another stainless duct carries the air exhausted through the oil cooler out and under the radiator.
B
BUNDYRUM
Hello HealeyPassion,
Another fine project update, well written and documented. I love looking at your website.
Hello Randy Forbes,
I like what you have done even though I would have done it differently. I like the duct from the opening to the oil cooler matrix. I would have used aluminum alloy rather than stainless because of dissimilar metals. Also the same for the rivets. I would have used solid rivets. Yes a little more difficult to install but that's me. The "cherry" rivets will come loose eventually as they don't like vibration.
HealeyPassion was lucky in that his shroud was off the car to do this.
Best regards,
bundyrum.
HealeyPassion
HealeyPassion
Randy, I really like how you handled the ducting behind the shroud....very slick!
Cheers,
Steve
Cheers,
Steve
Thank you, no point in putting that hot air into the (water) radiator :wink:
Bundy, since when do Healeys vibrate? :crazyeyes:
andrea
One other good step -I follow you on the way
also my car should be with Sebring Ducts
and Oil Cooler- the same model of Randy-
with thermostatic control on the spin Filter
also Lin Rose have made this mod but with different size - if I remember well (6"x2"3/4)
Steve the Oil cooler can be useful for your powerful
car- the addition can be easy at your build status
Andrea
https://picasaweb.google.com/searunner44
https://web.mac.com/linwoodrose/My_...-Three_files/Oil Cooler Vent Measurements.jpg
HealeyPassion
HealeyPassion
Andrea, interesting that you mention Lin's ducts. Yes, Lin's are a bit different size but the concept is similar... yes, he did his first and was part of the inspiration for mine.
I have an oil temperature gauge so I'll know if I need to add an oil cooler....given how I plan to use the car I don't think I'll need it. I have one screaming fast car that I track so I plan to use this for touring and romps in the mountains.
Cheers,
Steve
B
BUNDYRUM
Hello RandyForbes,
From the day they were born.
For those of you whose cars don't vibrate I don't need to know.
Best regards,
bundyrum.
HealeyRick
Steve,
Beautiful work as always. I probably should have incorporated these and the side vents to get some heat out of the engine room, but my bodywork and paint are all done, so probably too late. Your stick on patterns gave me an idea, though. Maybe I can get some fake vents made out of that vinyl material the NASCAR racers use to make headlights and grilles. At least I can look the part.
B
BUNDYRUM
Hello HealeyRick,
That's a great idea having fake vents, would save a lot of time and effort.
But seriously, your car isn't all together yet so I'd say this is the perfect time to do it. With a little bit of care you shouldn't need to do too much paint touch up.
You have already shown us the excellent standards you work to so why not?.
Best regards,
bundyrum.
HealeyRick
Bundyrum,
Much as I'd like to take an undeserved compliment regarding my work standards from an aviation metalworker, my late Mom and Dad (who BOTH built engines at Pratt & Whitney during WWII) would come back to haunt me if I did. I'm willing to try anything once and have made a fair amount of mistakes that I've learned from. So by now, I have a pretty good idea what I can and can't do and leave the stuff I'm not good at to the pros. Cutting up sheetmetal and trying to paint match Healey blue are way above my skill set. I have thought a bit about ways to install fender louvers without welding. Seems to me with today's bonding materials there should be away to run a flange around the vents and bond the flange to the inside of the fender. The scary part would be cutting into the fender without damaging the paint.
Cheers
GregW
Platinum
Well Rick, if you don't want to cut the shroud, maybe you could do something similar to my approach. I put the cooler between the frame rails and built a scoop to both direct the air and protect from road debris. Full thread is HERE
Frankenhealey
Here's another version
Oil cooler position
New scoop with grille
Underneath
Now look hard at the middle photo, consider the headlights as eyes, the grille as the nose and the oil cooler duct as the mouth.
Yes Folks, I think we have an extra from Pixars 'Cars' animation.
HealeyPassion
HealeyPassion
Rick,
The issue with the side fender vents is that you are joining a flat surface (vents) to a curved surface (fender). Todays bonding agents would probably handle the job, but getting the contours to look good without body work would be the issue. It was clearly above my skill set....so my trusty body guy handled mine.
Cheers,
Steve
B
BUNDYRUM
Hello Frankenhealey,
I just managed to get onto the V8 forum only to discover you own the late Greg Greathouse's BN1.
I first met Greg in 1982 then from time to time at various vintage race events here in the San Francisco bay area.
It's nice to see what you have done to the car and undoubtedly maintained the spirit of the way Greg originally built the car.
Best regards,
bundyrum.
HealeyRick
HealeyPassion said:
Rick,
Cheers,
Steve
Hadn't thought of that issue, Steve. Thanks. Guess it's back to the pasties for me.
Best Regards,
Celtic 77 MGB 77 MG B oil cooler MG 5
B Oil cooler Austin Healey 21
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
MikeAH100M Interesting Oil Cooler Austin Healey 6
H oil cooler and overheating Austin Healey 12
JPSmit engine oil cooler question Spridgets 11
RAC68 Routing Oil Cooler Lines Austin Healey 16
Scotsman TR2/3/3A How to Mounting Oil Cooler on TR3 Triumph 3
DanLewis Oil cooler hose fittings - 5/8 UNF versus 3/8 NPT Spridgets 2
DanLewis Solved the oil cooler mounting problem in my Bugeye! Spridgets 8
DanLewis Other ways to mount an oil cooler on a Bugeye Spridgets 3
DanLewis Oil cooler hose adapters? Spridgets 12
Branson oil cooler mount Spridgets 20
6 Oil Cooler Spridgets 3
R oil cooler need for 1500midget with 9:1 comp ratio Spridgets 3
H oil cooler overall cooling component Austin Healey 7
P broken oil cooler fitting MG 1
D oil cooler Spridgets 12
hondo402000 getting rid of my oil cooler, hoses, thermostat Triumph 2
V How much extra engine oil with oil cooler??? Spridgets 5
8 TR4/4A TR4A After market Oil Cooler Triumph 5
DerekJ Is my oil cooler a waste of time? Austin Healey 1
S Oil cooler and spin on filter adapter Triumph 10
tri_carb_healey oil cooler question. Austin Healey 5
hymodyne GT6 spin-on oil filter adapter w/ oil cooler GT6 Triumph 12
B TR6 TR6 Oil Cooler hoses Triumph 1
rikiwho123 oil cooler kit Triumph 0
D Help! Blew an oil cooler hose. MG 17
A Oil Cooler Washer MG 4
M_Pied_Lourd TR2/3/3A TR3A Oil Cooler Opinions Triumph 5
Sebring222 MGB MGB Oil Cooler Thermostat MG 4
Tabcon Oil Cooler Install Help Racing 0
angelfj1 Oil Cooler Leak Triumph 8
jaegzie Do/Should I use an oil cooler. Spridgets 11
losmorob Looking for an oil cooler kit Spridgets 7
chrpark oil cooler install and fitting pictures Spridgets 1
0 1500 oil cooler Spridgets 3
B GT6 GT6 Oil Cooler Kit for TR6 Application Triumph 3
tony barnhill '63 Midget Oil Cooler Hoses Spridgets 5
angelfj1 Oil Cooler Leak Triumph 9
J Oil flow direction and oil cooler Spridgets 14
Jim_Gruber Oil Cooler Hoses / Rerouting / Hole Saw Spridgets 5
Baz Oil Cooler lines... Spridgets 0
G Oil Cooler question Triumph 14
beez Oil Cooler with Thermostat Installation Question Triumph 8
B 1500 Oil Cooler Spridgets 7
Jim_Gruber Oil Cooler Hoses - Routing and supporting Spridgets 10
D Oil cooler MG 6
WALTER Benefit of an oil cooler Austin Healey 7
Jim_Gruber New Oil Cooler and Engine Temps / Pressures - Resu Spridgets 2
