Benefit of an oil cooler
WALTER
I was thinking of adding an oil cooler to my 3000 Because until the car gets quite hot my oil pressure is fine. Has anyone added one and has it made a difference. It worked for one of the Sprite guy. Seems like it should help
Walter
Keoke
Hi Walt, What is your oil pressure when the engine "gets quite hot " , what is that running temperature and what viscosity oil are you running---Keoke
I put an oil cooler on my Healey in 1985. I recently machined my own adapter and replaced the oil cooler and hoses due to age cracking of the rubber.
More pictures: https://www.rfdm.com/gallery/album50
The gray car in the signature pic came with an oil cooler from the factory. I retrofitted the same OEM parts to the black car and saw a 20 degree drop in oil temperature compared with before. Warm up is still quick, as the newer (2001-2002) BMW oil filter housing has a thermostat built in.
WALTER
WALTER
Keoke
- Running temp 190. It's more the amount of time I've been driving.
- Oil 20-50
- oil pressure about 10 at idle, 40 something cruising
- 65lb at start up
Randy - looks very nice but I'm not seeing an oil filter.
Walter
WALTER said:
Keoke
- Oil 20-50
- 65lb at start up
Walter
It's there...
This was more for a shot of the starter, but the old oil cooler adapter (modified original) and oil filter are visible:
WALTER
WALTER
Remote filter for new setup?
W
Keoke
WALTER said:
Keoke
- Oil 20-50
- 65lb at start up
Walter
Well with those numbers it seems you may have a bit of wear in the engine someplace. I would have a look at the rocker shaft first and then the By pass valve next for easy starters. Adding an oil cooler is going to include some additional pressure drop in the system----Keoke-?
G Benefit of fuel injection Triumph 10
C Forum benefit Austin Healey 1
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
