Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
There is a shroud available that clips on the cooler for use in cold weather to limit the air flow through the matrix. Don't know if it was a factory design or aftermarket. VB has them in the catalog for the 13 row cooler.
If you are trying to increase the temp of the oil for whatever reason you could simply install a couple tees and valves to bypass the cooler when you wish to boil your oil away.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
