Off to visit the police
Stewart
Stewart
Car got nailed by some poc who took off without leaving a note. Most likely going to need a new rear quarter, tail light assembly, bumper mounts and maybe the bumper. Didn't find the damage till this morning. Cars under normal insurance so I'm now out 500 bucks to get it fixed if I can find a shop in town that will fix it assuming the insurance company doesn't try to total it.
The sad thing is my parts finaly showed up on saturday and on sunday afternoon I finialy finished the mechanical restorations and a few hours later it gets hit.
Administrator
Boss
Akkkk! Had that happen once just days after I'd had my EType painted! Witness saw the perp too, but didn't get a plate number!
tony barnhill
Great Pumpkin - R.I.P
Tha can be pulled & worked by a good bodyman.....tough luck though.
GeeBee1
Yes, a little banging and pulling (some heat) should do it.
Sorry to hear of your misfortune.
Pat
Stewart
Stewart
Hopefully it can be pulled. The local body shop that does work on the older cars is 65/35 that it can be pulled. Right now it's looking at 1500 in repairs if it can be pulled.
I empathize with you....it will come out fine, I'm sure.
testaj
Member
That damage, without a doubt, can be pulled and hammered out. Sorry for your misfortune, but for the guy that hit you and ran I have one thing to say to him/her:
KARMA IS A BI@#H
Stewart
Stewart
Well I finally got the car back from the shop and for the did a decent job with the body work however the insurance company decided to use a used part to replace the tail light. Generally this is fine as a good used part is better than anything available new today however the one they sent was complete junk. It appears to be slightly bent its broken in one spot and cracked in another and the lens was so bad I put one of the originals from the car back on. Apparently they paid 75 bucks for it while a new one is 30 bucks more. I also loved the job they did on reinstalling the reverse light which they also broke in the process. Now I just have to wait for the adjuster to call back so the tail light can be fixed and this can all be over with.
tony barnhill
That almost looks like they put your old one back on & just charged the insurance company for a new one.
tony barnhill
Ditto to that Marv.
Stewart
Stewart
Well they just approved buying a new one so instead of just paying 105 + shipping for the new one plus the labor to install it they are going to end up paying 180 for parts and install X2. Hopefully they can get their money back on the old one.
Why is it there is always enough time and money to do things twice but rarely enough of either to do it right the first time?
Platinum
Edsel Murphy explained it, Pete.
Bruce74B
In this case, it is "Why do something right the first time, if you can get paid to do it again?" Our insurance dollars at work.
K TR2/3/3A Old school battery shut off switch....... Triumph 3
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
B TR4/4A Headlights Blink Off Triumph 15
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
Editor_Reid Knock-Off Hammer Austin Healey 8
kodpkd Signing Off Austin Healey 8
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
T Knock-Off Spinners Austin Healey 43
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
G Engine Will Not Turn Off Austin Healey 10
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
T TR4/4A Fenders off the car for paint? Triumph 8
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
R Turn Signal Knob goes off center Austin Healey 9
J BJ8 flywheel take some pounds off Austin Healey 17
A Setting Camber Really Off Austin Healey 13
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
JPSmit So I guess I don't need to lay off the churros after all Spridgets 4
S TR2/3/3A Frame off vs. body on restoration Triumph 21
Basil Easy[er] way to get frozen brake rotors off Restoration & Tools 13
B TR4/4A Can't get rear extension off. Help! Triumph 24
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
JPSmit Off to bed for the winter Spridgets 10
TomMull Knock Off Tool Restoration & Tools 6
S MGB When your breaks off. who ya gonna call......? MG 2
L Tight spot on steering box is way off Austin Healey 18
R TR4/4A Speedometer off 10mph Triumph 6
Boink MGB MGB-GT off-roading? MG 4
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
J Gas pump auto shut off question Austin Healey 2
Got_All_4 TR6 How does this steering lock come off Triumph 9
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
Got_All_4 TR6 Rear Panel Reflector off a parts car? Triumph 8
D TR2/3/3A off topic , but can you help with a quotation Triumph 5
T TR4/4A Heater control valve - cant completely turn off Triumph 3
JPSmit Off to British Car Day Spridgets 8
D cut-off switch Austin Healey 20
D TR2/3/3A curious tachometer take-off Triumph 5
Joe Schlosser Transmission Tailshaft housing off center Spridgets 3
Jim_Gruber New Shoes, New Shoes Bugsy got to show off his new shoes today. Spridgets 6
jfarris TR2/3/3A Off the shelf oil filter Triumph 9
A turn signal knocked off center Austin Healey 14
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
CJD TR2/3/3A Knock Off Differences Triumph 13
S TR2/3/3A bezels off the switches Triumph 5
