Off to have a mole removed
jlaird
Will pick up some STP to build engine. Or maybe what ever is used today.
Platinum
STP's good, Jack. White grease only if you KNOW it'll get fired up soon.
jlaird
jlaird
Got some stuff in a tube that they say is what's used now. Says all the right stuff on the back.
Like protects from rust, will not harded and clog oil lines, protects bearings when first starting, etc.
Platinum
but does it remove moles? /ubbthreads/images/graemlins/devilgrin.gif
jlaird
jlaird
Yep, mole gone.
You know I hate this Haynes manual.
What I need is a real Bugeye shop manual, loved it, was even printed on good paper and things were easy to find with larger print. Diagrams were excellent and instructions clear. Haynes must have been written by contract employees.
K TR2/3/3A Old school battery shut off switch....... Triumph 3
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
B TR4/4A Headlights Blink Off Triumph 15
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
Editor_Reid Knock-Off Hammer Austin Healey 8
kodpkd Signing Off Austin Healey 8
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
T Knock-Off Spinners Austin Healey 43
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
G Engine Will Not Turn Off Austin Healey 10
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
T TR4/4A Fenders off the car for paint? Triumph 8
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
R Turn Signal Knob goes off center Austin Healey 9
J BJ8 flywheel take some pounds off Austin Healey 17
A Setting Camber Really Off Austin Healey 13
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
JPSmit So I guess I don't need to lay off the churros after all Spridgets 4
S TR2/3/3A Frame off vs. body on restoration Triumph 21
Basil Easy[er] way to get frozen brake rotors off Restoration & Tools 13
B TR4/4A Can't get rear extension off. Help! Triumph 24
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
JPSmit Off to bed for the winter Spridgets 10
TomMull Knock Off Tool Restoration & Tools 6
S MGB When your breaks off. who ya gonna call......? MG 2
L Tight spot on steering box is way off Austin Healey 18
R TR4/4A Speedometer off 10mph Triumph 6
Boink MGB MGB-GT off-roading? MG 4
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
J Gas pump auto shut off question Austin Healey 2
Got_All_4 TR6 How does this steering lock come off Triumph 9
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
Got_All_4 TR6 Rear Panel Reflector off a parts car? Triumph 8
D TR2/3/3A off topic , but can you help with a quotation Triumph 5
T TR4/4A Heater control valve - cant completely turn off Triumph 3
JPSmit Off to British Car Day Spridgets 8
D cut-off switch Austin Healey 20
D TR2/3/3A curious tachometer take-off Triumph 5
Joe Schlosser Transmission Tailshaft housing off center Spridgets 3
Jim_Gruber New Shoes, New Shoes Bugsy got to show off his new shoes today. Spridgets 6
jfarris TR2/3/3A Off the shelf oil filter Triumph 9
A turn signal knocked off center Austin Healey 14
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
CJD TR2/3/3A Knock Off Differences Triumph 13
S TR2/3/3A bezels off the switches Triumph 5
