No spark - Revisited
vping
Bronze
I got a battery in the '74 and turned it over. Sounds very strong & has great compression. No spark.
Horn & lights work as well as wipers & hazzards.
I still need to check most connections to make sure they are not corroded.
When the PO parked the car 10 years ago, she had just replaced Condensor, wires, plugs, cap, rotor & points and it looks like it. I know most of you would recommend changing those which I plan to do but not at this moment.
How do I trace the electrical from A to Z to make sure that I am getting power to where I need it first, second...
Platinum
The "most likely suspect" is FUZZY POINTS! Did you clean 'em with some fine emery cloth? Check for voltage at the coil, put a 12V test light at the CB side of the coil and see if you have "trigger" blink (it won't fire with this)when spun and if not, the points are somehow fouled. Most likely if the coil has voltage and the thing won't light off the points are corroded.
Report back!
Dave Russell
Yoda - R.I.P
Just to elaborate on startech47's comment, It's not clear if the car ever ran after the PO replaced the points. Very easy to get the movable point's spring anchor end assembled wrong so that the shouldered insulating washers are not insulating the movable point springs anchor end from ground. This arm which is connected to the coil must only be grounded when the points are closed.
The spring anchor post (threaded) from point plate up should have:
1- A shouldered insulating washer against the plate with it's inner shoulder facing up.
2- The large eye in the point spring fitting over this shoulder.
Above the point spring eye:
3- The eye of a short wire on top of the point spring eye which goes to the side housing insulated block (point connection to the coil).
4- Next the eye of the condenser lead on top of the side connection lead (3) with it's hole centered.
5- A top shouldered insulating washer with it's inner shoulder down & insulating the inside of 2,3, & 4 from the post.
6- A lockwasher & nut over the top insulating washer which secures the stack.
7- A small flexible ground lead from the point plate to one of the point plate to housing hold down screws.
Some points also require a flat insulating washer between the pivoted end of the points & the point plate. This can usually be determined by the point to point vertical alignment, or whether any metal on the point pivot is contacting the mounting plate.
A simple check - Ignition on - points open - should read 12 volts from the coil to distributor connection. Points closed, should read zero volts.
Hope I haven't "over explained"
Rick_Stevens
My 2 cents' worth: Startech47 and Dave's comments are the first place to look. I made this mistake this summer when I replaced the points, in spite of knowing better. Easy to do wrong, easy to fix. (It sounds complicated, but once you see it in action - if that's the problem - you'll go "Doh!")
R.
Bruce74B
Dave,
I don't think you "over-expained" but gave the best description of the stack that I have ever seen...one to be printed out and saved for future reference! Thanks! /ubbthreads/images/graemlins/cheers.gif
Bruce
Platinum
T'was good.
...and ~I'm~ the one to say "Doh!" I didn't consider the possibility of grounded points... even tho I've DONE it (to) myself. Not just ONCE, either. /ubbthreads/images/graemlins/smirk.gif
jlaird
And that is excellent, it needs to be in the knowledge base if someone can and Doug will give permission.
Someone???
dklawson
I keep several PDF documents at the link above. They are free to post anywhere they will be of help.
jlaird
Ok folks, you heard the man. Please add to knowledge base.
Guinn
Very good advise from all. And just yesterday my neighbor, restoring a 1924 Willis Knight asked for ignition help. I found the spring that activates the movable point was sloppily attached to the insulated post and was grounding out against the base of the distributor. FWIW,
Guinn
dklawson
Shorting the points to ground is also easy on the Lucas 23/25D and 45D distributors. The little spade lug on the condenser wire can be inserted in a manner that it touches ground. On the 23/25D dizzy's there are also insulating washers that are often put back wrong (or not at all) and that will short the points out.
K TR2/3/3A Carbon buildup in an intake manifold and on spark plugs....... Triumph 3
trglory TR2/3/3A TR3a spark plugs Triumph 1
CARSINC Spark plug thread size Spridgets 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
Carlbanan56 MGB No spark and engine cranking slow MG 10
kodpkd Spark Plugs Austin Healey 3
P TR2/3/3A NO spark at points Triumph 36
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
B Healey Won't Start - No Spark Austin Healey 38
L TR4/4A spark plugs Triumph 9
BierRunner TR6 Life without Spark :( Triumph 25
J TR2/3/3A No spark in TR3 Triumph 20
G TR4/4A TR4 Lacks Spark! Triumph 22
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
tr6web TR6 No spark 1972 TR6 Triumph 35
PAUL161 T-Series Odd spark plug encounter! MG 10
MadRiver No Spark Austin Healey 18
K TR2/3/3A Testing spark plug wires..... Triumph 11
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B Anyone have spark advance data for Piper camshafts? Spridgets 1
B TR4/4A Spark plugs Triumph 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
S Spark Plugs Spridgets 2
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
AUSMHLY When to replace spark plugs Austin Healey 1
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Spark Plug Gap? Triumph 4
FlyingCat Spitfire Spark to Coil Triumph 23
K Numbered Spark Plug Boots? Austin Healey 27
tahoe healey Spark Plugs Austin Healey 20
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
mgedit TR2/3/3A Lost Spark Triumph 26
jfarris TR2/3/3A Which spark lug to use - copper/platinum/iridium Triumph 14
S No spark, im in the dark. Spridgets 6
G spark plugs Austin Healey 10
B Spark Plug Wire Caps Austin Healey 16
Sopwith_Camel MGB the mysterious disapearing spark MG 21
S Wedge Need help with TR8 no spark Triumph 7
vickxxx T-Series 1952 MGTD spark plugs. MG 4
S MGA 1956 MGA negative ground, True Spark Ignition distributor MG 3
B TR6 Spark plug gap Triumph 5
toysrrus TR6 Spark plug question Triumph 23
