MGB MGB exhaust replace
aroostok
Have to replace the exhaust system on 76B that was converted to dual carb (SU) set up. The old exhaust is a Monza systerm. When ordering from Moss should I get the system for a 76 or 74 and earlier? Is the only difference the hanger?
Sebring222
If you are going to keep the dual carb set-up you need to order the earlier system from Moss. In making the conversion to dual carbs, the exhaust manifold was also replaced for an earlier version. There are two down pipes in the earlier version vs. one down pipe in the single carb version.
tony barnhill
Great Pumpkin - R.I.P
Yep, what he said.
greenBtanner
Before you order a Monza, check for a Bosal. I've installed a Bosal 15 years ago on my '75 MGB and it's like AS I'VE DOE IT LAST MONTH. Bosals are guaranteed as long as it is installed on the car and the sound is genuine MGB. However I strongly recommend, whichever brand you select that you have a flexible insert installed between the manifold and the catalytic converter. This will prenent excessive and frequent loosening of the exhaust to manifold conection and visits to the muffler shop , tickets for Ā«driving straight pipeĀ» and exhaust infiltration inside the cockpit.
tony barnhill
Have your own built - if you have the old manifold & down pipe, go to your local muffler shop & have them match the diameter of the outlet of your down pipe with aluminized pipe...put an 18" or 24" <span style="font-style: italic">cherry bomb</span> under the driver seat & a 14"-er at the rear....then pich out a nice stainless tip to set it all off....same as all the expensive exhausts but much less expensive!
ccougill
what Tony said, a good muffler guy is a friend to be cherished
tony barnhill
chuck - where'd you come from? haven't heard from you in ages.....
ccougill
been a busy summer Tony, daughter got married and Laura has spent some time in the hospital
tony barnhill
Congrats on daughter......hope Laura's recuperating well.
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
S MGB Exhaust rubbing on steering column 77 MGB MG 23
dklawson MGB MGB Intake/Exhaust Needed - [re-posting] MG 7
drooartz MGB Stock vs larger exhaust [MGB] MG 10
G MGB MGB exhaust system MG 11
6 MGB 1977 MGB Exhaust Leak MG 0
N MGB 1979 MGB exhaust replacement. MG 1
19_again MGB MGB exhaust heat shield MG 3
RickB MGB-GT Exhaust system options 70 MGB-GT? MG 7
wkilleffer MGB Removing the exhaust manifold on an MGB MG 15
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
S MGB Exhaust 75 MGB MG 5
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
